Old March 5th, 2018, 13:31
JTProuhet JTProuhet is offline
PRP seats
Never thought about it that way.. Lol you have a point. Only one way to find out lol
Sent from my Pixel XL using Tapatalk
Old March 9th, 2018, 23:06
David_Bricker's Avatar
David_Bricker David_Bricker is offline
PSR Fire Marshall
Re: PRP seats
Originally Posted by Anak View Post
That is nice that they will let you run them and then send them back.
Get us some install pics, and I would also appreciate the difference in clearance between your head and the roof. How much do you gain/lose compared to the stock seats?
Come out to PSR in March / April and you can see for yourself!
David Bricker / SYR
Gomer - '95 XJ, 2 dr. 4.6L Russ Pottenger Stroker; Novak TJ AX-15; Black Box 2.72:1 + 241OR 4:1; RockJock 60 Front, hydro assist, Hi-steer; D60 trussed and shaved rear; 4.56 ARB Front and Rear; Black Magic discs, Bilstein 7100s front and rear; 35s; PRP seats; Warn PowerPlant winch, hybrid cage. Annd, the Faux Dorkle is gone.
National Treasurer 2013-2019
Not a member? Become one today, and help support YOUR club.
Old March 12th, 2018, 11:17
clydefrog's Avatar
clydefrog clydefrog is offline
Re: PRP seats
Got around to installing them. Had to make new brackets. Super happy with them. Not as plush as the factory seats but way better support. They are very comfortable, warm in the cold weather, about the same size (rear passengers wont be smashed) and the factory seat belt seems to work well. They are about 1" shorter which is nice. So far they are a bit difficult to get in and out of, I am 165lbs at 5' 11". I am sure I will get used to it. The upper part is wider so not much room between the seats. Build quality is extremely nice compared to the price (I think they could charge more).
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old March 12th, 2018, 13:17
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: PRP seats
When you say they are about 1" shorter do you mean 1" more space between your own noggin and the roof or that the back measures 1" less in height?
IOW, is it your own rear end that sits lower, or the headrest that sits lower?
Old March 12th, 2018, 13:29
PRP seats
I also got around to installing mine. IMO they sat an inch higher than stock seats. And using PRP brackets on stock mounts, the seats sat leaned back too far for me. So i chopped the front of the brackets and lowered them about an inch and a half. They are much more comfortable than stock. But are a pain in the ass to get in and out of. I figured thats just because I'm not a little guy.. 6'0" 280lbs
clydefrog's Avatar
Re: PRP seats
The seat height is about the same (headrest height vs stock headrest height). The whole seat is 1" lower. I built the brackets that way on purpose though as I wanted to be a bit lower, that's the one thing I hate about the XJ, the seating geometry is was to high. So yes, I gained 1" additional space between my head and the roof.
Old March 12th, 2018, 20:50
Anak's Avatar
Mostly Harmless
Re: PRP seats
Thank you.
That suggests I can pull this off one way or another. If not with PRP's brackets then with brackets of my own fabrication.
Old March 12th, 2018, 21:30
clydefrog's Avatar
Re: PRP seats
Thank you.
The brackets were super easy to make. Use my pick as a guide. They were 1/8" by 1" angle iron.
For Sale : Zj or maybe Wj leather seats, Grey, power seats and rear 60/40 split blondejoncherokee Sierra Chapter For Sale 5 December 5th, 2014 12:56
WTT Black Leather ZJ seats ready to bolt into xj for 97+ cloth seats twodoorXJ NAC Classifieds 10 August 27th, 2011 08:26
Power WJ seats in a 2001 XJ with manual seats anthrax323 Modified Tech Discussion 3 August 6th, 2010 12:19
2008 Grand Cherokee power seats into a 1997 XJ with manual seats Camo-5 Modified Tech Discussion 22 September 19th, 2008 03:51
Stock 97 TAN front seats - Just the seats / no sliders Hammered NAC Classifieds 6 September 16th, 2008 13:24
