Old March 11th, 2018, 08:58
snakemanc6 snakemanc6 is offline
Questions after my first lift
Hello everyone,
I just finished lifting my 2000 XJ. I went with an RC 3" series 2 lift, and gained about 3.5 in the front and 4 in the back. With the kit i also replaced the LCAs, and an adjustable track bar.
I've barely driven it since i completed the lift. It developed the expected vibrations, so i'm having a local shop install a SYE and driveshaft for me Monday. In the little ive driven it i have noticed a few things that im hoping you might have some advice for.
1. I upgraded wheels and tires to 31x10.5x15, 15x8 wheels with 3.75 backspacing. I'm getting a fair bit on rubbing around the bumper end caps and rear of the flares. I trimmed the bumper end caps and that's helped there, but just found the rubbing at the bottom rear of the flare. I know i can trim things here and there, but i see so many posts of people saying that they fit similar tires on similar setups and dont have to trim anything. Also, if they're rubbing pulling into my driveway, i'm guessing it'll be awful on the trails with sway bar disconnected.
2. My brakes seem a good bit worse now. I know they aren't know for stopping ability to begin with, and i increased my unsprung weight with tire and wheel upgrades but it SEEMS to stop so much slower now. It could be that i've gotten used to driving our other vehicles the past few weeks (and am overthinking it), but i'm not sure. I did replace my rear brake line during the lift, but i bled the brakes, saw no air, and the pedal doesn't sink. It just seems to slow/stop much more slowly than before.
Ive not yet had my alignment done after the lift. That'll be done Monday as well. Not sure it that will have any impact on the stuff above.
Mainly just wanted to see if anyone has any advice or thoughts on this. It's my first XJ as well as first vehicle i've ever lifted, so it's all a learning process for me. Any info you might have would greatly appreciated.
Thanks everyone
Old March 11th, 2018, 13:15
sinat01's Avatar
sinat01 sinat01 is offline
Re: Questions after my first lift
I would check the control arms, are the adjustable? if so you may need to fine tune them a bit.
bigger tires will hurt your brakes some, but you can always upgrade the pads, do a rear disk swap, etc. adjust your rear drums, they love to go out of adjustment.
Old March 12th, 2018, 11:59
RCP Phx RCP Phx is online now
That rim size and backspacing is the source of your rub. Brakes always are less effective with larger tires. Diagnose what you have, then there are upgrade options!
lift help and questions wrestler5005 Modified Tech Discussion 6 August 23rd, 2005 00:39
Lift Questions K2XJ Modified Tech Discussion 4 March 5th, 2005 05:29
More lift with D44 questions...... gptherezonlyone Modified Tech Discussion 0 January 16th, 2004 19:28
Lift questions srkruger Modified Tech Discussion 2 December 3rd, 2003 21:09
s10 lift?/5 inch lift questions lucasxj Modified Tech Discussion 4 August 4th, 2003 22:35
