Old February 13th, 2020, 09:48
Black1990jeep Black1990jeep is offline
Exhaust Couplings
I am about to install a new catalyst, and want to make both ends bolt on, rather than the factory way. I want to add a bolt on connection of outlet of the catalyst to the muffler.
I am considering these Walker Ball Flange types ...
https://www.summitracing.com/search/...ibanner=SREPD5
is there any down side problem with this plan?
I want to do this cause...1) I had a catalyst clog on a trail, and want the ability to easily remove it to clean it out if need be. 2) I may want to remove it for off road use where there is a risk of fire danger do to dry grass.
What do you all think about these Walker Ball Flange couplings?
Thanks!
Old February 13th, 2020, 14:58
madmax's Avatar
madmax madmax is offline
Re: Exhaust Couplings
I need this a few years bac I highly recommend it.
Old February 13th, 2020, 15:00
madmax's Avatar
Also add a flex joint or two
Old February 13th, 2020, 15:09
sandfreestyle sandfreestyle is offline
Can also look into V-band clamps.
Old February 13th, 2020, 16:02
RCP Phx RCP Phx is offline
Better choice but they use the flare/double flare tubing.
Old February 13th, 2020, 16:53
ehall's Avatar
ehall ehall is offline
most Walker parts are zinc coated mild steel and will rust away
I like the stainless V clamps, but can be hard or expensive to have stainless welding work
my '91 beater rebuild
Old February 13th, 2020, 21:32
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
I use slip-fit pipes with stainless steel band clamps.
Everything is stainless, simple, inexpensive, and
easily maintained...
madmax's Avatar
Weld, paint (high temp) and forget. You will get years of good use
Old February 14th, 2020, 09:20
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
These flex joints are strong and corrosion resistant. V-bands make for easy removal of exhaust components.
Build Thread: https://www.naxja.org/forum/showthre...913774&page=18
Speak the Truth-Question with Boldness-Speak without fear.
Old February 14th, 2020, 15:03
ehall's Avatar
a few years, many years from stainless
Old February 14th, 2020, 16:46
I am liking the band clamp, but the butt type verses the lap type, for easier removal, installation.
The vee clamps look kind of like vacuum line fittings, minus the gasket, or oring, but they are pricey, and require welds all around.
So I am leaning to the Band Clamps, Butt Type
Something like this...
https://www.amazon.com/dp/B07RYML3CK...dDbGljaz10cnVl
Thoughts?
Old February 14th, 2020, 17:17
ehall's Avatar
https://www.amazon.com/dp/B07RYML3CK...uc_pt_expsub_1
Thoughts?
I use those in two places under my trail XJ--one at the front where the downpipe connects to the flexpipe in front of the cat, and another at the rear where the muffler connects to the tailpipe. I wanted to have it separate under load when I hit the muffler or tailpipe. The front clamp separates often, but the rear has never separated. I am looking for a stronger clamping action, or maybe tack the band to the pipes so that it will still break but less often.
XJ JEGS Exhaust, Stock Exhaust, No Exhaust, Video 96Sportxj Modified Tech Discussion 5 March 12th, 2019 11:28
Does an exhaust gasket leak smell like exhaust? SuperRA OEM Tech Discussion 9 September 24th, 2013 17:23
Protecting quick connect couplings for OBA Jeep-Guy Modified Tech Discussion 3 June 27th, 2006 01:57
