Old February 12th, 2020, 19:41
docneon docneon is offline
New exterior door handles do not fit!
I am in the process of restoring my 89 XJ. Before it went to the body shop, I pulled all of the trim including the door handles which snapped the studs off despite my best efforts not to. I ordered a set off of Amazon that says it fits from 1984-1996 and user reviews seem to agree, at least for the 90s. Tried installing them but the studs are about 1/4” too close together. When I looked up parts on a MOPAR site, it lists different part numbers for 1989 (55007467) and 1996 (55024927) both for driver door in black.
What gives? Are the mounting holes different? I realize that I can elongate the hole on the one end, but thats hella expensive fresh paint!
Old February 14th, 2020, 08:41
xjnp242 xjnp242 is offline
Re: New exterior door handles do not fit!
Strange they slightly changed the door handles for '89 only.
Are the Amazon and OEM handles identical except for the stud dimensions?
If so and i wanted to make the Amazon handles work.....
I'd bite the bullet new paint or not and elongate the stud holes with a very fine round section file.
But first i'd put painters tape over the areas to be filed and only use file strokes into the Jeep to minimize peeling off any paint.
I would elongate both stud holes to keep the handle centered as much as possible. Then pull the tape off gently towards the filed area.
Then using a fine brush, paint the filed areas to prevent rust and paint peeling.
Other than that, only other option is to find the correct '89 P/N handle.
Old February 15th, 2020, 09:20
Saudade's Avatar
Saudade Saudade is offline
Even stranger my parts catalog show different part number for 87-89, and 90.
5500 7466-7 AR 1987-89
5502 4926-7 AR 1990
The amazon listing for my 88 specifies the 1990 part number.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old February 15th, 2020, 10:45
RCP Phx RCP Phx is offline
Crown's version only list's from '90........
https://www.crownautomotive.net/Door.../55024927.html
Old February 15th, 2020, 11:32
Saudade's Avatar
Yeah, the Crown links match the '90 part numbers. They seem good to '96. In '97 the part number changes again.
Old February 15th, 2020, 18:16
Like i thread earlier, Mopar changed the part number for rear brake shoes in 3/10/2000.
Why? Nobody seems to know.
This PN thing is getting weirder and weirder.
Maybe the XJ was discontinued because Mopar finally ran out of part numbers. haha
Old February 16th, 2020, 13:20
Unfortunately, I threw out the broken handles 6 months ago when I took them off and knew I couldn’t reuse them. Now I have nothing to compare to, but it is all 4 doors. None fit! Well, I made them fit without elongating the hole, I put the end with the push button in first and then stretched the plastic far enough to get the other bolt through the hole. No nuts needed to hold them in place, but I think I’ll use them anyway! If I could post pictures, I would.
I did use plenty of tape around the openings to protect my beautiful paint.
Old February 16th, 2020, 17:39
Plastic under tension has a way of cracking over time, hope it doesn't happen.
Anyhow, do the new handles actually work?
Exterior Door Handle keith_b00ne OEM Tech Discussion 6 December 21st, 2013 17:34
ZJ exterior door handles SuperRoo Modified Tech Discussion 9 July 31st, 2013 11:57
LCA's and Door Interior Door Handles thanasi85 Sierra Chapter For Sale 1 June 2nd, 2013 09:49
exterior door handles are stiff Maz OEM Tech Discussion 5 September 22nd, 2008 07:09
XJ Exterior Door Handles TiRod OEM Tech Discussion 0 November 7th, 2003 15:46
