Old February 10th, 2020, 21:01
Base2Final Base2Final is offline
New To me XJ Trans drag
Hola, So I just bought a 90í XJ from a friend. He took a motor and trans from another XJ, same year and had them both rebuilt and installed himself. The Jeep ran last back in 2014. I literally drained the bad fuel and replaced it with new gas and it fired right up. Took it for a drive around the block and about 800 ft into it, it died but immediately restarted albeit a little rough. I assume it was still working out the old s**t gas. Bottom line, I put it back into drive and now it drags hard like I have the E brake on. I can put the trans on 3rd or 1-2 and it drives fine. But in drive I have to really gas it to get it to move at all ( like the Emergency brake is up ).. Reverse is good. Just let off the brakes and itís rolls on itís own through all the gears but Drive.
Any ideas? Iím no trans expert but wondering if itís maybe a cable setting or of something got clogged and I need to take it in somewhere.
Thanks
90í XJ 4.0 auto
Old February 11th, 2020, 04:47
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: New To me XJ Trans drag
Start with the basics, check all the fuses, make sure the trans is full of fluid, make sure the fluid is the specified Dexron-III/Mercon and NOT ATF+4, check all the wire harnesses to the transmission for chafed or melted wire insulation, and rodent damage. Make sure all the wire plugs free of corrosion and are firmly connected.
If transmission will shift manually 1/2 - 3 - OD, suspect the Transmission Control Module, wiring issues, or perhaps a faulty trans solenoid.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old February 12th, 2020, 09:33
One would think this is my first time in any forums! I found the issue. The TCU was simply not there. I bought the Jeep and the interior is completely out of it. I did see that big ole plug dangling there but yeah, after searching I see what it is. Thanks for the reply though!!
Old February 12th, 2020, 10:24
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Thanks for getting here with the cause.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old February 12th, 2020, 16:32
Tim_MN's Avatar
Originally Posted by Base2Final View Post
.... I found the issue. The TCU was simply not there.
Very suspicious.
Old February 14th, 2020, 05:52
75SV1 75SV1 is offline
Did you put in a TCU and drive it? I have driven with the TCU unplugged. I do not remember that I had any issues with it in D. And yes I drove it over 1200 miles. I could be wrong as it has been 3-5 years ago. I would suspect the NSS.
Old February 14th, 2020, 07:53
Yeah I drove it around my block for about a 1/4 mile. It died likely due to working out the bad fuel left in the fuel lines/filter from 2014 lol
I restarted it then put it in D, it wouldnít drive for s**t. Drive fine in 1/2 and reverse.
I just bought the Jeep from a friend. Everything under the truck is new. Motor, trans, transfer case etc. he had gutted the interior and most of the dash and lost interest in the project. Lucky for me! Picked it up for a song but, now Iím picking up the mess. After searching I found the TCU still bolted to the dash that was in a pile in my garage lol
Plugged in, drove it again and shits normally through all gears now
How do I remove trans cooler lines from trans?? esirol OEM Tech Discussion 10 September 3rd, 2014 12:25
Installed trans cooler, now trans sounds horrible? El Taco OEM Tech Discussion 9 June 28th, 2012 17:17
Trans heat killing ur trans? honesT OEM Tech Discussion 1 November 4th, 2010 11:26
Location of manual trans fill & check plug for an Aisin Trans 90 Cherokee gman OEM Tech Discussion 2 September 24th, 2004 20:20
does downshifting with an auto trans to slow or brake hurt the trans lapaul OEM Tech Discussion 12 February 21st, 2004 09:26
