- MilkyWay Galaxy
Trying to help a lady 1500 miles away..... 4.0
So far replaced the battery, replaced the starter, was sure that solve the problem. Cables and clamps are good. Same problem we had with 1 year old starter and 1 year old battery.
While cranking the battery voltage drops to 9 volts, and the engine is doing maybe 5-10 rpm at best.
When they first started they jumped the old battery/starter and got it to run and the battery voltage was 13.7 volts while running.
Oh, it is 97-98 ish rig.
But then I had the person helping her clean the clamps and cables, test the cranking voltage. it was dropping to 9-10 volts while cranking and that is why we replaced the battery and starter. Battery first, then later the starter. Even with new Battery and Starter, it will now barley turn over.
Plan is to tow it and have the valve cover removed, look for obvious issues and than hand turn the crank shaft to see what might be wrong top side.
Keep in mind, it ran earlier after having an initial issue (unclear what the original issue was).
The last 2 start tries, it was like it made 2-3/6ths of a full rotation, second try was worse 12 then it was like it was trying to rotate but was bushing on a brick wall, fully bogged down.
Since the 4.0 is not an interference engine, and it ran after the earlier problems, with a jump start, I leaning towards a valve/valve spring/lifter/rod issue, but I am not even sure that could cause this problem.
So I am a bit stumped. Looking for expert ideas from engine experts on what could happen internally and cause this. I do not think a stuck closed exhaust valve could do this? As that would be the same as a compression stroke right? The engine should still rotate / crank way faster then 1-5 to 10 rpm????
