Old August 4th, 2019, 20:06
SkatingPenguin SkatingPenguin is offline
Cracked frame rail @ steering box
1997 cherokee sport 4.0 automatic and all stock w/ about 280k. The crack is just ahead (towards bumper) of steering box and top side of rail. original SB and bolts snapped off in January this winter. replace with new SB and new I had quite a large crack due to previous front fender bender but was not proactive. Now, 7 months later all 3 bots snapped and hopefully I can thread out the portions sticking out the opposite sides. So, I've found a wealth of knowledge in here, repairs, etc, but have a few questions as I try to game plan how to attack this issue. Some things I'm curious about as well. I don't normally do my own repairs except the small things. something like this I'd probably get some oversight from some friends who have the more serious tools and experience. Its been my daily driver since purchase, original owner, and woulld like to keep it going.
1) has anybody gone the route of purchasing the OEM part (Mopar #4798085AB side rail/member)? I see it on Wholesalemopar.com for about $700.00. Is it the money for everyone? Or is it not the best avenue for other reasons?
2) I understand i may have to clean up the area should I go the direction of the weld repair. I know people who can assist with that.
3) i've seen the addition of a bracket and bar that span across to the opposite rail to another weld to prevent the SB from moving left to right. I'm not sure I'd need to get that so far but its an interesting support.
4) Also see the option of adding frame stiffeners, of course after I clean up the area.
any comments or suggestions would be appreciated. I don't necessarily need a write up sent my way since I've identified a few threads but if you have something at your finger tips send it my way.
lastly, trying to upload photos w/o using a link.
Thanks
Old August 6th, 2019, 11:21
trippled trippled is offline
Re: Cracked frame rail @ steering box
I would do this. You can add a few stitch welds to the plate and it would be pretty good.
https://www.c-rok4x4.com/c-rok-onlin...ners-p38115469
Replacing the frame rail would be a massive undertaking. No one does it because it's not worth the time and money involved and there are other options that work well.
Old August 6th, 2019, 13:51
denverd1 denverd1 is offline
Depends on how bad of a hit you took on driver front corner. I had similar damage to rail. I added front stiffeners and added a good bit of steel to rebuild bumper mount then reinforced the inner rail.
Depending on your damage, a piece of angle welded in there might help hold things together. I had some rotational flex before I beefed things up.
Old August 8th, 2019, 08:02
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Speaking from experience. I ended up scraping my XJ after it cracked the unibody. Was more work than I wanted to put in. I also got a MJ out of the deal so was a win in my book.
Do as trippled suggested and go with the crok kit. Also frame stiffners are a must.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old August 8th, 2019, 09:12
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
This is what I did on my 94 to repair the same issue. Had the crack welded, then put the c-rok plates in.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old August 8th, 2019, 09:21
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Hooligan makes an inner/outer frame stiffener
https://www.hooliganoffroad.com/coll...ont-stiffeners
Cracked Frame The Box South East Chapter 32 September 2nd, 2009 19:10
Cracked Frame (Steering Box)-Fixes??? SharkXJ Modified Tech Discussion 16 November 5th, 2007 14:24
Steering Box frame rail plating Gravesdiggerxj Modified Tech Discussion 13 June 18th, 2007 11:39
cracked frame mgt SoCal Chapter 10 May 30th, 2007 10:35
Pics of my cracked frame due to steering box brace Handlebars Modified Tech Discussion 30 April 23rd, 2003 09:55
