Old August 4th, 2019, 14:35
asymptonic asymptonic is offline
DIY Undercoat
I'm having to have some unibody work done due to an idiot rear-ending me. They will likely be cutting a tiny bit for the repair, and I'll bet anything I'll have bare spots down there...
What do y'all recommend as an undercoat to keep rust away that I can apply myself to a small area. I'm in TX so this isn't mission critical but I do want it to last.
1998 4.0 I6, AX15, NP231
Old August 4th, 2019, 16:30
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: DIY Undercoat
If you do not drive on oceanside beaches or on snowy road salt treated roadways, any paint will be fine. I would use POR-15 or something similar.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old August 4th, 2019, 20:16
Re: DIY Undercoat
I have some Rustoleum rust converter and some exterior oil based paint that I used in a pinch. Por-15 is hard to find in small quantities, right?
Old August 4th, 2019, 20:21
Re: DIY Undercoat
NM, its easy enough to find online, though not super cheap.
Old August 5th, 2019, 06:58
CJR CJR is offline
Re: DIY Undercoat
I've used POR15 in the past. Now I'm using water-based Rustoleum black epoxy, w/activator, on an off-body 72 Jeep Commando resto and like it alot.
Water clean-up and slight water thinning is also nice.
Best regards,
CJR
Old August 5th, 2019, 09:01
Heavyopp Heavyopp is offline
Re: DIY Undercoat
Take a look at Chassis saver -- Same idea as por15 but cheaper
Old August 5th, 2019, 17:10
Re: DIY Undercoat
Best regards,
CJR
Is epoxy not too rigid for this? Feels like it would crack.
Old August 5th, 2019, 18:41
CJR CJR is offline
Re: DIY Undercoat
Asymptonic,
Answering your question on the flexibility of epoxy is not so easy. Twenty or thirty years ago there were about 800-900 formulations for epoxy. Today I would guess there are thousands and thousands of epoxy formulations. If it doubt on your application, discuss using the Rustoleum water-based epoxy "5300 System" with Rustoleum and see what they have to say.
Best regards,
CJR
Old August 5th, 2019, 20:24
Re: DIY Undercoat
Thanks. Knowing its the 5300 system helps, I'll look at the material data. Completely understand your point about the formulations and applications.
Old August 7th, 2019, 08:05
BALTANAKT BALTANAKT is offline
Re: DIY Undercoat
POR-15
Old August 7th, 2019, 09:54
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
Re: DIY Undercoat
I read a guys build where he used top secret coatings on his rig and seems to like it. I think it's marine based so fairly durable.
I believe por-15 is supposed to be painted over as well, it at least no exposed to UV.
Old August 7th, 2019, 12:30
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Re: DIY Undercoat
I used the Rustoleum spray undercoating on my rear wheel wells after doing a cut and fold. I'm on the Texas coast and it seems to have done the job fine.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old August 7th, 2019, 17:11
Re: DIY Undercoat
Galveston? Sounds encouraging. How long has it been on?
Old August 7th, 2019, 18:45
Re: DIY Undercoat
About a year.
Iím in Houston but go to Galveston a lot
John V.
RRC VP
Old August 8th, 2019, 00:39
tm8chris tm8chris is offline
Re: DIY Undercoat
Aside from being cheaper than por15, Chassis Saver is a one-step process.
Home job Body undercoat? jhc7399 Modified Tech Discussion 6 April 18th, 2015 11:42
