Old June 3rd, 2016, 17:42
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Shifter interchangeability early/late?
So I was doing a search and didn't find much on this matter just the bezel and other tidbits.
But can you direct swap a late model aw4 shift lever that is inside over to a early model? With my 91' I'm seeing how the straight shift lever can cause my knuckle to hit the center console but in my 97' the shift lever is curved and a bit easier to use. If it isn't direct swap what would be needed to swap it over? Might as well fill my curiosity if I ever chooses to swap it.
Old June 4th, 2016, 07:24
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Shifter interchangeability early/late?
I think they do swap.
Old June 4th, 2016, 14:23
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Auto shifter is plug n pray. The bezel/gear indicator might not be correct, if just swapping the shifter.
Time for a 97+ center console swap..
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
AW4 swap early to late spctrbytz OEM Tech Discussion 17 January 26th, 2018 19:43
early rear flare on late XJ? N8N_99xj Modified Tech Discussion 5 August 19th, 2012 12:04
Late dash into early XJ...I did search. XJRocket Modified Tech Discussion 1 January 3rd, 2009 06:50
wnated early 90's late 80's xj rwallace Wanted: Private Party Only 1 January 7th, 2007 15:34
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 12:48
