Old July 31st, 2019, 07:49
fetishfrog fetishfrog is offline
Crown HD coil springs uneven
Hey all
About 8 months ago, I replaced all my springs with Up Country equivalents, Crown HD in the front, General Springs in the rear.
Rear has settled in at just over an inch higher than stock, and even. The front however, the passenger side is 1/2 inch higher than the driver's side.
Has anyone run into this issue with Crown HD springs before? How did you fix it? I've considered swapping them to see if they even out (as it's usually just me in the car) or replacing with Moog/other (is there an other for Up Country spec springs?).
Thanks
Old July 31st, 2019, 08:19
RCP Phx RCP Phx is offline
Re: Crown HD coil springs uneven
The factory front springs carried different part numbers, I would consider a spacer on the low side.
Old July 31st, 2019, 10:45
Sorry, I am not following your first comment. Do you mean different year XJ's had different part numbers for coil springs for the Up Country option?
I used this spring for both sides. Spring
Old July 31st, 2019, 12:25
No, that Jeep had a left and right spring.
Old July 31st, 2019, 13:34
I did not know that.
Thanks.
Old August 2nd, 2019, 12:25
Well, I've been unable to locate the different part numbers for the different springs, and I don't see it mattering much as Mopar coils seem rare and no one else makes separate parts for the left and right, that aren't higher than I want to go so...
Anyone else have this issue?
Otherwise a see a spacer in my future.
Old August 2nd, 2019, 12:29
old_man's Avatar
old_man old_man is offline
Swap the left and right and see if the difference follows. If it does, demand a refund/replacement.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old August 8th, 2019, 17:36
JrTxJ JrTxJ is offline
^What he said.
Depending where you bought them, they'll send you replacements up to 12 months if you put in for a warranty claim.
You never know if someone packaged/labeled/shipped you two different springs. They sell 4 different stock XJ springs so it's possible.
If you haven't, closely inspect your spring perch. Rotted perches are common around me.
Crown leaf springs cmahaff Modified Tech Discussion 25 October 19th, 2015 21:24
Dorman or Crown replacement leaf springs for street XJ rav Jeep Street and Performance 8 July 20th, 2014 09:34
Crown Leaf Springs rmz45099 SoCal For Sale 2 July 7th, 2014 21:28
New Crown Stock Front Coil Springs imthehink For Sale: Private Party Only. XJ ITEMS ONLY 1 April 16th, 2007 17:46
