OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
new trak bar, still clunking at the lower bushing
So i've had the usual trak bar clunk on my 90 cherokee for awhile. (stock, no lift, no big tires..). I installed a new trak bar from napa. cranked the hell out of all the bolts, still clunked.
mystified until today when i finally traced it to the lower bushing. The bolt is NOT moving in the hole. the hole looks fine. So, did i get a defective trak bar? I tried another bolt as well, same clunk. Should i put in a urethane bushing? should i not worry about it? (it's pretty much only if i jerk the wheel fast or am backing out of a parking spot). It's a pretty minimal amount of movement, but of course it's fairly loud as it's between the axle and the frame, no damping anywhere. the thing drives great, tracks well, no trouble over bumps. |
#2
My first thought is are you sure its the track bar. Had similar clunk when backing and what not and turned out to be control arm bushings.
#3
Re: new trak bar, still clunking at the lower bushing
Are you sure the steering stabilizer bolt isn't loose? I chased that one for a while and it's pretty close to the trackbar bolt.
#4
are you still using the stock bolt on the axle side? i found that because the stock bolt is not shanked the entire length of the bushing, it wears down and allows movement.
if you are sure this is where your slop is (not trying to insult your diagnosis. just visually verified it) if that is it, take a set of calipers and measure your bolt, bolt hole, and diameter of the bushing sleeve. my suggestions is to drill everything out to the same size. i found my bolt, bolt hole, and bushing sleeve were ALL different. install a bolt with enough shank so that the bushing does not sit on threads. you may have to cut one to length. i bought a really long bolt, put a die on it, and cut threads to the length i wanted. on a side note... dont just tighten bolts with bushings RFT. there is a specific torque rating for a reason. it sets preload on the bushings and ensure longevity. too tight will squish them and make them wear prematurely. if everything measures the same, this may be why your clunking returned after it appeared fix. Last edited by VAhasnoWAVES; June 7th, 2012 at 06:58. |
#5
So you're basically suggesting i go to an oversize bolt? I actually put a new grade 8.8 bolt in. It measured about .004 larger in diameter at the shank. I'll see if i can find another reasonable size up. I don't doubt that all the holes are different sizes. the clunking has never "appeared fixed" it's been ongoing and basically unchanged despite 2 track bars and various tightening and fiddling. is there any chance that the mount on the axle has bent open a bit? I see what you're saying about having the correct torque spec so that the mount is squeezing the sleeve the right amount. |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
any one have the internal measurement of an XJ lower control arm bushing cradle? | ericfx1984 | Modified Tech Discussion | 27 | February 6th, 2011 15:57 |
bushing replacement for RC fixed lower control arms | Lightfoot | Modified Tech Discussion | 2 | May 14th, 2010 10:58 |
Trac-bar lower bushing. | -96JeepSpeed- | SoCal For Sale | 15 | February 7th, 2008 21:34 |
trak-lok? | burkemotorcross | OEM Tech Discussion | 5 | June 27th, 2007 12:41 |
XJ stock Lower CA bushing | Dazz | Modified Tech Discussion | 15 | June 23rd, 2004 20:14 |
