Old September 8th, 2008, 17:09
Justpunchit's Avatar
Justpunchit Justpunchit is offline
NAXJA Member #1291
filter change with TNT Y-Link
I talked to phil a long time ago at tnt customs, when I first bought my y link and he said people can actually do a filter and gasket without dropping the belly skid... well I got all the bolts out except the last back two, anyone actually do this? or does everyone give up and drop the skid?? thanks for the help.
Old September 8th, 2008, 17:39
stewie's Avatar
stewie stewie is offline
Re: filter change with TNT Y-Link
dont know about the filter and gasket part, but this weekend i drilled a 1 1/2A" hole in the belly pan so that i can drain the trans fluid without having to take the skid off.
Old September 8th, 2008, 17:57
NAXJA Member #1291
I really thought about doing that, it can't hurt the integrity that much I'd imagine.
Old September 8th, 2008, 18:01
CROSBIKE's Avatar
CROSBIKE CROSBIKE is offline
i have done it. to make it much easier remove the 4 nuts holding the tranny mount to the skid and jack up the tranny by lifting it with a jack placed on the rear yoke from the tcase. I did it with mine and its much easier to move your hands up there. or just use some extensions and u joints
Old September 9th, 2008, 06:19
NAXJA Member #1291
yes! theres hope I'll give that a shot today.
Old September 9th, 2008, 17:46
CROSBIKE's Avatar
howd it go?
transmission and filter change woes the_bandit87 OEM Tech Discussion 3 May 21st, 2006 00:07
Oil filter location change? asatxj OEM Tech Discussion 20 March 9th, 2005 13:12
Tranny pan and filter change 90Pioneer OEM Tech Discussion 15 November 13th, 2004 12:28
Tranmission Filter Change problem? Jeepster4wd OEM Tech Discussion 16 April 3rd, 2004 21:27
aw4 fluid and filter change Poison OEM Tech Discussion 2 July 6th, 2003 11:11
