OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Oil filter location change?
I'm getting tired of making a mess trying to the the oil filter removed. My '91 motor had the oil filter vertical right by the distributor. When I swapped in a '97 it was horizontal so I left it. Is there any reason why I can't remount it vertical like my old motor??
#2
Re: Oil filter location change?
Go to www.madxj.com and look in the technical section for engine upgrades
#3
I've been there, they talk about changing to the hroizontal filter but not going vertical. Unless I missed something.
#4
I use an old bread loaf metal pan and set it in there under the filter after I have loosen it. it collects all the oil with no mess.
#5
Rotate the L-adapter 90 degrees and use the original metric("207" style) filter. At the bottom page in the summary. Do the reverse. |
#6
You may be able to rotate the mount, but the filter threads stay the same - use the same filter - the older style with the metric threads won't fit.
#7
You can also wrap an old bread wrapper or other plastic bag around the oil filter before you remove it. The bag will catch any dripping oil....
#8
I may just rotate it. The biggest problem is the nut who puts the filter on too tight because he doesn't want it to leak
#9
10-30 way to low viscosity I have always run 20-50 quaker state and never had any engine problems. 95 is on 250,000 miles and still within 1% of original factory specs on compression etc. |
#10
20-50???? I wouldn't be able to start it half the year with molasses in my engine. Mine lives outside in Michigan and 20-50 is way to heavy here, maybe in the dessert SW like Arizona, not here.
#11
HMMM I live at 7000 ft altitude and the avg winter temps are about the same as yours. we have had over 100 " of snow this year
#12
Ok, so why run 20-50, the owners manual says 10-30 for my application. Now, if you have issues with compression or oil burning the heavier grade may be helpful. I ran 20-50 in a old Ford Fiesta for no good reason and when I switched to 10-40 I picked up 2 mpg. I wasn't burning oil so the change in grade didn't harm a thing, just let the engine work less hard.
If you rock crawl a lot where excessive engine temps are an issue then I can see a heavy oil but not when I do DD and trail use that isn't >1mph I rarely use 4lo as I don't do that type of trails. If you do, then it may be a good idea. naturally, opinions are like noses, everyone's got one. |
#13
I never do any oil in any vehicle under 10-40, never have to me the 10-30 is a minium reccomondation. and most of what I use em in is highway vehices. It has just been my experience over the past 30 years of driving I get less engine wear and able to push the vehicles harder running heavier oil. shoot my 95 has over 220,000 miiles on it and still within 1% of original factory compression and the oil remains clean for about 2000 miles.
If I ran the reccomended 10-30 in our shelby glhs the oil pressure would never rise above 20 and knocks like a mofo. with 20-50 no knocking and 65 psi. In the comanche 2.5 4 cyl I have little if any blowby into the air cleaner with 20-50 and about a quart a month with 10-30 anyone running an older pre HO xj will get much better results with a higher viscosity oil as requards to ail in the air filter. and will run smoother also. In my seat of the pants experience |
#14
I'm going to have to try that next time. |
#15
you could just get a remote filter setup and put it wherever you want , plus then you could run different type of filters , dual filters, cooolers , or a bypass.
I got my dual remote set up for under 50 bucks if I remember right. It is set up 2 run 2 of the large Ford filters. |
Thread Tools | |
Display Modes | |
Oil Filter won't fit block! | ADam J | OEM Tech Discussion | 8 | February 23rd, 2004 21:48 |
leaking in area of the oil filter | gman | OEM Tech Discussion | 2 | December 8th, 2003 00:02 |
remote tranny oil filter location | urbanXJ | Tow Rigs and Trailers | 4 | July 15th, 2003 11:29 |
Oil leak in area of oil filter, need help | gman | OEM Tech Discussion | 8 | June 5th, 2003 15:12 |
OIL in the distubuter?!?!?!?!?!? | Stoney | Sierra Chapter | 5 | March 4th, 2003 05:24 |
