Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old June 3rd, 2020, 18:59
RavenMocker's Avatar
RavenMocker RavenMocker is offline
MJ still wonít start! 🥺
1988 MJ 2.5 with manual. One day it just stopped running. So I troubleshoot it down to the fuel pump. Bought a new fuel pump and it ran. Everything was going well and then it wouldnít start. I can hear the fuel pump turn on when ever I turn on the ignition. I have spark and fuel but it wonít start.
I decided to do a tune up. It needed one anyway. Replaced spark plugs, rotor and cap, spark plug wires, the CPS. Even after all the cranking the battery still reads 13.7 vdc. I put new grounding straps in battery to body, body to engine, battery to engine. Still wonít start.
Iím at a dead end. Any other suggestions? This is driving me crazy.
Old June 3rd, 2020, 19:19
Re: MJ still wonít start! 🥺
It tried to start and then popped and back fires thru the throttle body. I still have spark and fuel.
Old June 3rd, 2020, 20:32
Did I post this in the proper forum?
Old June 4th, 2020, 11:09
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
I'd start here http://cruiser54.com/
Then I'd go here.
https://comancheclub.com/
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old June 4th, 2020, 18:28
As you try to start it 98% of the time it won't fire up at all. It won't even act like its going to start. It just turns over and over again doing nothing. But the few times it tried to start the engine started and then rambled and popped and backfired through the throttle body.
I checked the CPS again and it ohms out correctly and the voltage it proper.
I eliminated C-101, one wire at a time and second checked all wires prior to solder and heat shrink. Still not starting up. I rechecked all the spark plug gaps, the new spark plug wires to be certain they are clicking down on the spark plug and the distributor cap. We still have spark. I checked all vacuum lines and other wiring and their connectors. The battery still reads 13.5 VDC. I have not ran number one cylinder up to TDC and checked the rotor bug. I wanted to try all this first.
We are getting fuel but I don't know what the new fuel pump is putting out in pressure.
This came from the factory as a 2.5L with an Automatic 2x4. The PO swapped it to a manual. I'm dreading pulling the dash and checking all wires and those running down the steering column.
Old June 5th, 2020, 12:46
I replaced the ECU with a known good unit and it wonít start. Cylinder one to TDC and rotor bug points to plug one on the distributor cap. I retested the new CPS and the ohms/voltage is dead on. Now moving onto the TPS and MAP.
Old June 9th, 2020, 17:31
TheCodeMonk TheCodeMonk is offline
I mean...fuel, spark, air. That's all there is to it. You said you're confident in the fuel going into the cylinder? Spark tested at the spark plugs right? Beyond that, just verify valves are letting air in.
Sent from my Pixel 4 using Tapatalk
2001 White XJ (t-boned - RIP 5/27/19)
3.5" Long Arms (Full Traction) Lift + ACOS and HD Offroad shackle drop, 35x12.5r15, Bushwhacker Flat Flares, JCR Crusader [winch front bumper, non-tire carrier rear bumper, sliders, gas skid), Waggy D44 front w/elocker, 8.8 rear with worn out LSD.
1991 Blue MJ Pioneer - 5.3 LM7, 4L60e, NP231, 33s, 3.54 gears, D30/D44, SOA Lift (~5.5 in the front)
Old June 11th, 2020, 00:53
Cleaned all grounds and added a few others. Cleaned all terminals and sensors, like pretty much anything I havenít done and did a few over. I did notice the CPS male pins were bent to one side. The boy must have bent them... after I straightened them out and made certain they were in the female sides it started up and he has been driving it for the past two days. I hope to gawd thatís it.
Hard Start when warm, easy start when cold Pinocpao OEM Tech Discussion 4 December 2nd, 2016 17:50
cranks but no start ran great shut it off wont start now scottybeach OEM Tech Discussion 18 October 23rd, 2013 16:05
Wont start; Rough Idle and then stalls when it does start MudslinginXJ OEM Tech Discussion 17 February 24th, 2008 08:30
A short kills my Battery right after start up. it will only start with a jump help! paxj1112 OEM Tech Discussion 4 June 30th, 2007 21:22
'88 Chief Rough Idle or No Start or Perfect Start Hawaiian Style OEM Tech Discussion 8 June 9th, 2003 15:51
