Old February 16th, 2010, 18:29
cardboard's Avatar
cardboard cardboard is offline
Change Trans filter
I need to change my tranny filter before WF and was wondering if Synthetic fluid will do me any good. I am just going to drain the pan pull the filter and refill. Chiltons says the pan holds 4 qts just dont know if I will get any bennys from the mix of Syn and Dino.
TIA Cardboard
Old February 16th, 2010, 21:51
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: Change Trans filter
You do know that it is not a filter, but just a screen--keeps the big chunks out.There is NO benefit to mixing trans fluid, keep plain old DEX III in it ,or DEXIII/Mercon .
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old February 17th, 2010, 02:00
cracked-butt's Avatar
cracked-butt cracked-butt is offline
^^^^^^^what he said ^^^^^^^
the only benefit is if you do a complete switch from dex to syn. dont bother mixing them. but if you do go syn, you cant switch back (from what i understand) once you go full syn you can't go back to "regular" dexronIII/mercon, same thing with motor oil too.
but that's just what i understand of the stuff, i haven't done any "real" research on it though.
Old February 17th, 2010, 04:34
ILLXJ's Avatar
ILLXJ ILLXJ is offline
Most here DON'T recommend using synthetic in the AW4. Do a search, they don't seem to like it. JIM.
Originally Posted by monkeyevil
Brian is just a puppet in my corporate empire. I like to give him little tasks to keep him busy and feel important... like talking to Mr. Hale on the phone
Old February 17th, 2010, 04:59
cruiser54's Avatar
cruiser54 cruiser54 is offline
The only part you should have on hand for changing the fluid besides the fluid itself is the little gasket for under the drain plug. It's likely to leak if not replaced.
Old February 17th, 2010, 07:53
Original_MudButt's Avatar
Original_MudButt Original_MudButt is offline
Originally Posted by cruiser54 View Post
The only part you should have on hand is the little gasket for under the drain plug.
You will most likely need an o-ring for the dipstick tube as well. Mine was completely stuck. The only way I could get it apart was with a heat gun, which ruined the o-ring.
Trans filter question? mgreen84 Modified Tech Discussion 4 December 19th, 2009 20:15
fuel filter change 93xjowner OEM Tech Discussion 5 October 4th, 2009 16:24
filter change with TNT Y-Link Justpunchit Modified Tech Discussion 5 September 9th, 2008 17:46
Oil filter location change? asatxj OEM Tech Discussion 20 March 9th, 2005 13:12
Tranny pan and filter change 90Pioneer OEM Tech Discussion 15 November 13th, 2004 12:28
