Old October 23rd, 2020, 23:21
Black1990jeep Black1990jeep is online now
Re: AW4 filter change pictures
https://magnefinefilters.com/
you can add an inline filter on the cooler inlet side of the tranny cooler hose.
see above link
I use this filter for both tranny and steering fluid filtering. install before the cooler as fluid should be filtered hot not cold.
Old October 24th, 2020, 08:11
maxbraketorque maxbraketorque is offline
see above link
Which size?
Old October 25th, 2020, 09:59
Originally Posted by maxbraketorque View Post
Which size?
the 3/8 inch fitting size worked for both my power steering and tranny hoses
this one...
https://magnefinefilters.com/NEW-Mag...8M-3810000.htm
this works for both fluids the website is weird in that they have a seperate listing for steering and tranny fluid filters, yet they are both the same part. I called and asked them for confirmation. So one type works for both fluids, no difference.
double check your hose diameter before ordering, mine is 3/8 inch on a 1990 XJ.
clean fluid rules!
Old October 25th, 2020, 10:12
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I agree on the filtering hot statement. Hotter will mean lower viscosity and therefore the magnetic filter will have a greater effective range to pull particles out of the fluid.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old October 25th, 2020, 14:14
lawsoncl lawsoncl is offline
Adding a filter shouldn't hurt. I wonder if magnets in the filter would be more effective than the magnets in the bottom of the pan.
Old October 25th, 2020, 14:46
RCP Phx RCP Phx is offline
I wouldn't think so do to the speed of the flow, you sure can't beat a good magnet in the pan.
Old October 25th, 2020, 20:27
The Magnafine filter has both a magnet and a pleated paler filter inside. It also has a bypass valve. I have cut one apart to find out.
Hot fluid filtering in addition to better magnetic capture of lartilces as stated is also of
help to reduce back pressure thru the filter media as thin oil flows easier thru the media. Less back pressure means less pressure loss and less bypassing via the bypass valve.
This is why be it tranny, engine, power steering, etc.., oils should be filtered prior to cooling.
I hose clamps the filters in place to the body panel just below the radiator, behind the bumper.
With the price of a tranny rebuild these days, A bit of extra filtering might be $aving money in the long run.
Change Trans filter cardboard OEM Tech Discussion 5 February 17th, 2010 07:53
fuel filter change 93xjowner OEM Tech Discussion 5 October 4th, 2009 16:24
filter change with TNT Y-Link Justpunchit Modified Tech Discussion 5 September 9th, 2008 17:46
Oil filter location change? asatxj OEM Tech Discussion 20 March 9th, 2005 13:12
aw4 fluid and filter change Poison OEM Tech Discussion 2 July 6th, 2003 11:11
