Old December 7th, 2003, 19:45
gman gman is offline
Question leaking in area of the oil filter
I have noticed an accumulation of motor oil at the bottom of my 1990 xj whenever I park. I checked under the vehicle and under the hood, I do believe the leak is coming from that piece that the oilfilter is attached to. Does this have seals that can be replaced, or do I need to replace the entire piece.
1. what is the name of it, and what do you suggest I do?
Old December 7th, 2003, 19:54
DaveD in Canada DaveD in Canada is offline
Re: leaking in area of the oil filter
Yes, there is an O-ring kit available to fix the leak around the filter adapter. I believe it is available only at the dealer, but is not expensive.
Old December 7th, 2003, 23:02
PaulJ PaulJ is offline
Three o-rings, shouldn't cost more than $5 at the dealer. It can be a pain to get the bolt out of the adapter. You'll find discussion about this if you do a search.
Oil comparison? brtb OEM Tech Discussion 12 March 22nd, 2004 23:43
Oil Filter won't fit block! ADam J OEM Tech Discussion 8 February 23rd, 2004 20:48
help oil filter adapter/elbow leaking tbear OEM Tech Discussion 3 September 27th, 2003 15:25
Oil leak in area of oil filter, need help gman OEM Tech Discussion 8 June 5th, 2003 14:12
OIL in the distubuter?!?!?!?!?!? Stoney Sierra Chapter 5 March 4th, 2003 04:24
