Old July 3rd, 2006, 00:15
AgentXJ203 AgentXJ203 is offline
Re: Rear Fender Trim Write-up, retaining the stock flare (Fender Trim Part 2)
I cut and folded on the rear with my 89 two weeks ago, and it's awesome. I placed mine up higher, required cutting the flare in two, and the front halves are actually mounted to the back doors. I did not re-use the stock hardware, as I secured the flares with screws. The whole thing is in the process of Herculining and sealing right now, and I will post pictures when it's done. Cutting fenders is the way to go.
Old July 7th, 2006, 04:55
FitchVA's Avatar
FitchVA FitchVA is offline
awesome writeup bro! i'm glad i could assist you an any way. outstandinng job. it looks awesome.
now it's time to get rid of those rear end cap brackets.
Old July 7th, 2006, 07:32
ZachMan's Avatar
ZachMan ZachMan is offline
Gone but not forgotten...
Whats the point of the caulk again? Just wanting to make it seamles insed th wheelwells? Just curious cause I did this months agao with no caulk and not had any issues. I just rattlecanned the little tabs and then bedlined.
Stem cell transplan 11/8/07
You tell him to put that thing in 4-low, take off his My Little Pony panties and drive it outta there
Old July 7th, 2006, 07:57
flexjay87 flexjay87 is offline
kudos for a good job, great write up and pics. you have a very nice looking and functional jeep.
Old July 7th, 2006, 10:04
FitchVA's Avatar
it's to help prevent any water from getting back there and accumulating. over time that could cause rust.
Old July 7th, 2006, 13:47
Brad M.'s Avatar
Brad M. Brad M. is offline
Thanks for a great writeup. Best trim job I've seen. By the way that's a pretty clean XJ ya got there... almost too pretty! Scratch that thing will ya?!
Old August 26th, 2006, 22:03
savage1978 savage1978 is offline
The most impressive part of this post is the fact that your woman is there with a smile on her face and helping ya out...I only seem to get the psychos!
Old August 27th, 2006, 03:21
53guy's Avatar
53guy 53guy is offline
Lol, yeah, that actually is the next trim job. I've (since the rear trim's been done) smashed my rear quarters up pretty good out in Crozet by imitating the space shuttle and they need to be cut and folded now. I just haven't decided how I'm going to do the end caps yet. I'll probably just order a set from Terry at Rigid Co, but I might just do something home made like Eric just did a few weeks ago. Either way, the quarters are history.
Old August 27th, 2006, 03:24
53guy's Avatar
Oh goodness its been scratched. Its definately a looker at 25 feet, but a pin striped wonder at 10 feet. I just try to keep a good coat of wax on the paint so that everything getting scratched off is mostly wax. It seems to work pretty well actually. But wax won't protect the bottoms from rocks! WHERE IS MARTIN!?!?!? (Martin at Rock lizard is helping me re design his super skink sliders around the Full Traction kit......it's definately take a bit longer than thought.)
Old August 27th, 2006, 12:30
mjd99xj's Avatar
mjd99xj mjd99xj is offline
Hey, nice pics and info. Im about to do exactly that. Question for ya- Im running the same setup for shocks (5150s in front and 5125s in the rear with lowered top mounts) What kind of rear bumpstop plate is that? Homemade? I have some plates that im trying to get to work using the top of the ubolts (plate on top of the nuts, then nuts ontop of the plate) And i like the look of your setup.. Any info would be great
Old September 12th, 2006, 15:58
Rock Rock is offline
Agent - Have you had a chance to take some pic? It'd be nice to see.
53Guy - Great write up on both the front and rear. Hope to do the same.
Old September 18th, 2006, 00:00
in2fords's Avatar
in2fords in2fords is offline
awasome write up and clean rig. too bad they rust out here before we get them off the dealer lot, price of paradise.
Old May 10th, 2007, 06:27
WoodyDE WoodyDE is offline
Where did you get the bump stop mount on top of the mounting plate for the rear axle?
Nice write up on the flares. I think I am definitely going to do this for the front and rear.
Old May 10th, 2007, 07:32
53guy's Avatar
Full Traction. They come with the lift kit. Thanks for the compliments.
Old May 10th, 2007, 07:55
uncc civilengineer's Avatar
uncc civilengineer uncc civilengineer is offline
Nick, quit writing and start taking everything apart.. just kidding... Seems like keeps some of your write-ups and loses others
Front Fender Trim Write Up (Retaining the stock flare) 53guy Modified Tech Discussion 112 March 29th, 2014 12:47
Another Rear Fender Trim 88XJScott Modified Tech Discussion 7 November 12th, 2005 19:47
How much fender can i trim on my MJ? LazarusMJ Modified Tech Discussion 6 October 3rd, 2005 17:01
Fender trim turdles Modified Tech Discussion 1 October 25th, 2004 17:06
rear fender trim rooster Modified Tech Discussion 4 August 28th, 2003 10:00
