Old April 12th, 2018, 10:32
Mighty.Mighty_XJ Mighty.Mighty_XJ is offline
Leaf Spring Swap ...
Quick question ... I know I'm supposed to use new U-bolts, but is it recommended to swap the spring plates as well?
Old April 12th, 2018, 11:04
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Leaf Spring Swap ...
If the spring plate are not excessively bent or rusted, they can be re-used.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old April 12th, 2018, 23:37
Cool, thx!
Ford 56" leaf spring swap with a twist cdawall Modified Tech Discussion 36 January 1st, 2014 15:31
Leaf spring swap question (lengthy) jb98xj Modified Tech Discussion 4 September 22nd, 2008 13:32
Leaf Spring Swap and Flip? 99xj4x4 Modified Tech Discussion 10 February 9th, 2008 19:37
Where to get spring hanger bolts and axle/leaf spring shims StockJeep Modified Tech Discussion 3 June 4th, 2007 19:10
leaf spring swap Q 93XJdude Modified Tech Discussion 2 June 25th, 2006 20:48
