Old April 15th, 2018, 18:02
RCP Phx RCP Phx is offline
Re: Dana 30 Pattern Check
I should add that the run-out has nothing to do with any shimming, it's caused by the machining tolerances in the carrier and the gears and even your installation. Do you deburr the carrier? Did you stone and deburr the ring gear? Did you heat the ring gear and chill the carrier before installation? What brand of gears did you buy?
Old April 15th, 2018, 18:34
Blue xj 99 Blue xj 99 is offline
I didnt do any of those things. They are motive gears and I made set up bearings which is what I'm using now. Made sure to use the different carrier for the new gear ratio.
Sent from my SAMSUNG-SM-N915A using Tapatalk
Old April 15th, 2018, 19:23
Heavyopp Heavyopp is offline
Do shops really do these things? -- Kinda sounds like using distilled water in a coolant system -- we all know it's the right way but find me a shop where you have ever seen it done...
Old April 15th, 2018, 19:24
If your able to measure the backlash, you can still measure the run-out. The important thing is the pattern!
Old April 15th, 2018, 19:26
No, but good installers can read a pattern and know what to do with it !!!
Old April 15th, 2018, 19:41
I am curious because you lost .003" in your different shim pack changing the backlash, where did that difference come from?
Old April 15th, 2018, 19:59
If you are taking about difference in backlash between the last comparison then all I did was move the thinnest shim from one side of the carrier to the other.
Old April 15th, 2018, 21:29
Originally Posted by Blue xj 99 View Post
NRG= .0785
RG= .02055
BS=.008
Pinion shims=.059
If the carrier bearing pre-load was set..............
NRG= .05590
RG= .04165
Pinion= .0355, Add .0204 for the baffle
Backlash= 10
What changed? What's your pinion bearing pre-load? Trying to help but over the internet(w/ bad pics) makes it tough to help w/o 20 questions. I want to suggest hopefully you could contact someone in your chapter that could see what your doing and advise.
Old April 18th, 2018, 12:29
cwyman6 cwyman6 is offline
I do this in my shop.
The pattern looks pretty good maybe .001 too deep but it has good contact patch so I would run .008 backlash and call it done. .003 in carrier preload isn't going to hurt anything as long as u have enough preload.
You would be amazed at the gearsets coming out of the factories now. Had one just the other day with zero carrier preload as it just fell out out once I pulled the caps. Vehicle had 1200 miles on it
Old April 19th, 2018, 10:18
Still playing around to fine tune the pattern. The last 4 pics I posted seem to be the best it's going to get (with as backlash of 10). Nothing has really come close to that since. I was able to find a shop near me that is going to help finilize everything. I'll post final pattern and specs after to help anyone else doing the same thing.
HP Dana 30 Pattern Check. CherokeePride99 Modified Tech Discussion 19 January 4th, 2018 18:12
d44 pattern check Vanimal Modified Tech Discussion 63 July 21st, 2012 08:28
Dana 44 Gear Pattern Check Please Begster Modified Tech Discussion 25 July 31st, 2008 19:51
HP D30 Pattern Check IntrepidXJ Modified Tech Discussion 30 June 18th, 2007 05:34
pattern check please massxj Modified Tech Discussion 7 May 16th, 2005 21:05
