Old March 31st, 2018, 17:04
jmg222 jmg222 is offline
the best learned lessons are often the hardest ...
recently ripped out practically the entire interior in my xj in preparation for a roll cage, while I was at it decided to rewire (battery is in the back, lots of messy wires that needed to be cleaned up).
Got everything re-connected and working , but for the life of me couldn't get the fuel pump to turn on. I'm running a terminator EFI on my 350, and had wired a safety switch between the EFI unit and the fuel pump relay. I tried everything.. ripped out all the trim so I could trace all the wires from the EFI to the fuel pump, triple tested the wires, replaced the relay, pulled every fuse. Gave up to leave it until tomorrow... and then realized... the fuel pump doesn't turn on unless the switch AND ignition is on.
Lesson learned -- the simplest solution is typically the answer, and even if it isn't, it's a good place to start. three hours of my life I'll never get back.
Daily drive: 2018 Jeep Grand Cherokee Trackhawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: 350 sbc, crane cam, holly performer intake, Terminator EFI, novak shorty headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old March 31st, 2018, 17:20
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: the best learned lessons are often the hardest ...
We've all been there!
Old March 31st, 2018, 18:04
Heavyopp Heavyopp is offline
On the same note -- 2000 XJ power door locks
I spent a few hours tracing wires and testing switches trying to figure out why only sometimes my door would lock with the switch -- finally figured out that they won't lock with the key in the ignition -- I feel your pain...
Old March 31st, 2018, 19:10
and I made it even worse... turn on the key, fuse pops. replace, check wires, turn on key, fuse pops. Took me two hours to realize that as I was tracing wires, I plugged the fuel pump under the truck into the wire harness in reverse.... power was connecting to a ground.
time to pack it in again, let it sit till the morning... making way too many stupid mistakes.
Old March 31st, 2018, 20:22
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Yup. Heading to an event in November my truck showed me no trailer brake connection. I spent 4 hours ripping all of the wiring out of the trailer and rewiring the entire thing, and then a second time, with no success - only to find that the 20" wiring extension for my hitch extension had become unplugged from my truck. Trailer was plugged in just fine, to an extension cord that wasn't plugged into anything..
Old April 9th, 2018, 16:17
ftwelder's Avatar
ftwelder ftwelder is offline
Just last week I spent several hours testing components and and fuel pressure only to discover I had the flipped the pressure and return hoses at the pump.
endless jeep project that will eventually end up as a rust bucket in someones backyard.
Lessons learned robbieyukon Jeep Street and Performance 3 May 25th, 2010 14:40
Lessons learned jimgrms Colorado Chapter 9 September 22nd, 2009 20:02
Lessons Learned Alienspecimen OEM Tech Discussion 5 September 14th, 2009 08:30
Two lessons to be learned- SCW Non-Tech / Off Topic 13 December 13th, 2007 21:39
First lift: lessons learned casm Modified Tech Discussion 5 April 11th, 2006 11:38
