Old April 15th, 2018, 12:34
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Re: Projext "V8 XJ" Build
Originally Posted by GordoSmasho View Post
If you have a paid membership you can. Jeep looks sick man. Makes me wish i didnt treat mine like crap.
You could also try tapatalk. Thats what i use. It hosts the pics for me right from my phone and it will resize them for you as you post. Gives you three size options too.
Yea I know you can get a membership but why strip that capability on a forum. This is the only one that does that.
Originally Posted by denverd1 View Post
Not to hijack, but tapatalk hasn't been working for me lately. I can access all the forums and subforums, click a thread to open and it spins forever. maybe I need to update it or something....
Rig looks awesome!! How much did your shackle relo kits add in lift? about to put mine on and not sure which front coil to pair up with them. I have extended shackles as well.
The bolt on relocation kits add about 1-2" of lift. How much lift are you going for?
Old April 15th, 2018, 12:36
PhotoJared's Avatar
Ok, We're getting this thing going again!
Ordered some injector spacers so I can use the stock truck injectors with the LS6 fuel rail. These weren't available when I first started the project but would have made things a lot easier.
I also ordered an Art Carr shifter....Lets see if we can make it work. I ordered the stock rock crawler pattern (i can go from drive to reverse in a straight shot).
Old April 16th, 2018, 14:59
PhotoJared's Avatar
I'm also re-doing a few things:
ORDERED:
Novak Radiator
Novak Fan Kit
Novak Fuel reg. bypass.
New fuel module
Old April 16th, 2018, 15:03
denverd1's Avatar
denverd1 denverd1 is online now
got 4.5" on there now using a full spring pack and stock shackles. Need to get to 6.5" in hopes of clearing 37s. Been told it will net 2" with extended shackle, so was just confirming...
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old April 17th, 2018, 20:46
clydefrog's Avatar
clydefrog clydefrog is offline
The art car shifters are awesome! And I love my Novak radiator, it works extremely well with the V8. I'm running it in a closed system with an expansion tank. The new rig is awesome BTW!
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old April 18th, 2018, 15:56
PhotoJared's Avatar
I'm excited to get it. I hope it can keep up in the Vegas heat. I'll be running it as an open system just like the stock XJ.
Old April 18th, 2018, 21:16
clydefrog's Avatar
I have towed in 110 heat with hills and it did fine. Running two 10" spal fans a a small cheap 8" fan. Rarely are both spams on and I run around 200f. Also I found that a small oil cooler really helps with the overall temp, something to consider....
Old April 20th, 2018, 12:42
PhotoJared's Avatar
Ordered:
- Fuel system check valve (I noticed longer than normal cranking times before)
- More -6 AN hose so I can re-do a few lines (Novak radiator also doesnt have a transmission cooler so I'll have to re-do those lines.
- New fuel pump module (might as well fix it now because I'm basically re-starting this swap)
Old April 26th, 2018, 14:12
PhotoJared's Avatar
Ordered a bunch of wiring and connectors.
Installed the Walbro 255 fuel pump installed in the module. Just need to drill a hole for the fuel return. I'll do that when I'm ready to do the install. Just trying to get as much stuff set up right now as possible.
Old April 26th, 2018, 14:21
PhotoJared's Avatar
P.s. this is the pump that I used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old April 27th, 2018, 10:29
PhotoJared's Avatar
I laid my first ever weld last night. Its just on some thin 16g stuff I had laying around from my overhead switch panel. I dont know a whole lot about welding but I didnt think it looked too bad.
Here's what the fuel pump assembly will look like (pretty much factory)
Old May 1st, 2018, 11:33
PhotoJared's Avatar
Received the Winters shifter. I think I can make it work without too much fuss.
Old May 1st, 2018, 12:23
PhotoJared's Avatar
So I may also switch over to a custom gauge cluster. What do you guys think?
Old May 2nd, 2018, 20:52
clydefrog's Avatar
I have that same exact shifter for the 4l60e. Direct bolt in. I vote custom cluster that way you can make it the way you want with the gauges you want.
Old May 2nd, 2018, 21:21
PhotoJared's Avatar
Can you post a picture of how yours is mounted in the center console?
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 294 April 27th, 2018 18:42
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 22:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 03:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 02:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 12:19
