Are there any of you that have gone to full width axles who are regretting it? I am on the fence with going full width and I want to hear from you guys to see if it is worth it.
None of all the guys I regularly wheel with have any regrests........because none of us have full width axles.
Sometimes it matters, sometimes it doesn't, a lot depends on where you wheel. You just take a little different line than the regular width guys. Now, if you're going to drive it regularly, that makes a difference. If I had to go cheap, I'd go full width, but if I had a choice I wouldn't.
There, a 2 cent opinion from someone who hasn't gone full width.
Just food for thought. I had dana 30/ 8.8 with 16x10 3.5" backspacing wheels with 35s for a few years. Went to full width 60s with H2 wheels 17x9 with a 5.5" backspacing. End result is only a few inches wider than I was before. Not sure what your plans are, but if you can find a good set of axles with 410 gears. You maybe not be looking at any work as far as rebuilding goes. Just install. The only thing I have considered was narrowing the front to 66". Mainly just to match the rear better. No regrets though. I also daily drive mine.
