00XJ216
- Cleveland Ohio
Hi everyone, Ive searched on line for some answers and came up with nothing so I figured I would ask the experts here.
I have 2 issues on my 2000 XJ 4.0 Auto...
First, the blower for heat/AC works when it wants to. When its not working I wiggle every wire and nothing hapoens. The blower motor, resistor and control head have all been replaced with working good ones.
Thoughts?
Problem 2, I have a leaking trans pan seal. Drained fluid, dropped the pan, inetalled new filter and reassembled and filled with fresh ATF+4. I should say I had to drop the dip stick tube with the pan because it would not seperate. After install and refill, it started throwing troubke codes for Torque Converter Circuit P0740. I erase it and the code comes back immediately. Any insight or help would be greatly appreciated. Thanks!
Thoughts?
