Old July 28th, 2006, 12:23
streetpirate's Avatar
streetpirate streetpirate is offline
Re: intake manifold
Originally Posted by MogifiedXJ
When you put an ho head on a renix block there are 13 (I think) water jacket ports in the head you have to have welded up then the entire head milled back down flat to do it correctly.
i believe this is only for putting an ho head on a standard 258, but not on a renix
Old July 28th, 2006, 12:28
MogifiedXJ's Avatar
MogifiedXJ MogifiedXJ is offline
Re: intake manifold
You right man...I've posted some stupid shit today I just need to quit...
Old August 17th, 2006, 23:31
gradon's Avatar
gradon gradon is offline
Re: intake manifold
I got the '99 manifold plus 2 window strips for $26.50 at Crazy Ray's below B-more. The power steering pump and bracket were already gone so I'm gonna have to make a trip back der.
Old August 18th, 2006, 03:57
stoneattic's Avatar
stoneattic stoneattic is offline
Re: intake manifold
You suck! I paid $100 for mine
Old August 29th, 2006, 19:02
gradon's Avatar
Re: intake manifold
SO I went back to crazy rays and all they had was a 98 wj w/ the pump and bracket that would bolt on the 99 manifold--again another 26.25. When I put it all on today the tensioner pulley on the new bracket wouldn't come up enough to tighten the belt. Off to AdvancedAuto to get a 5" longer belt (pn # 1030k6, $25) so that it can go AROUND the tensioner pulley with the ribside on the pulley. I have to swap the tensioner system 180 so that it'll pull down to tighten the belt, which means I'll have to bore out that hole on the bottom. So for me the whole cost and labor of the swap will be about $90, 4hrs install/mod, 2hrs @ Crazy Rays. Boycott those mobsters at Brandywine (unless you have a friend on the inside)
Intake manifold itadekimasu OEM Tech Discussion 2 October 18th, 2005 09:31
intake manifold Sephrion Jeep Street and Performance 21 March 3rd, 2005 01:39
HO TB and Non-Ho Intake Manifold cyberbackpacker For Sale: Private Party Only. XJ ITEMS ONLY 2 February 19th, 2005 10:53
99+ Intake manifold JeepSpeed Jeep Street and Performance 39 October 30th, 2003 15:30
does anyone have a HO 4.0 intake manifold norcalxj Sierra Chapter 16 September 10th, 2002 18:59
