For shizzle ma nizzle...looks good, Im building a similar dilio (brackets), but using the stock x-member as the foundation...much round tubing around it to reinforce...peace out.
You mentioned in another post about exhaust clearance. Is that clearance issue at the crossmember? Can you not just notch the crossmember like you did for the front drivesshaft? Now granted I baised this statement from the photos above and not having seen the rest of the Jeep, I might be off.
Beezil...please don't take this the wrong way.....but...I have noticed that my welds look allot like yours....does this mean that I am doing better than i thought?
Hmmmmm.... the overhead welding wasn't too bad. Its the cross-member and other removable parts welding that looks......
The truth be known....its appears like you are trying to finish a project right before you head out for some long anticipated wheelin'
(please note the hidden plea for sympathy for those of us who are not going to Moab :rattle: )
Please explain your front lower frame bracket to me. Did you just put that support on the crossmemeber as a compression only helper, or did you bolt the back of your bracket to the front of your crossmember?
:anon: I was looking at that before he put it together (still welding parts) Now that it is in, I would think that the flex as far as stuff drivers and drop pass, will bind or destroy the DS. But that won't be known until flex test at home.
