NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
Ok, getting back on track. Let's just say that the speedo and odometer are both reading accurately. They were checked with my gps. What other issues might cause poor mileage? Specifically, a 35% drop.
Gear ratio would effect the PCM / TCU inputs so the correct speedo gear
Over-all trans health (trans cooler, shift kit, correct ATF, etc)
Properly adjusted TV cable to insure good pressures
Good tires with correctly inflated air pressures
A cat or O2 sensors going bad
Any of the engine sensors failing, I don't see where you did any scanner testing
I'm at 5.5" on 32's with a 325+ HP stroker engine and get 18mpg on the highway!
