Heading up to Spring Creek in a couple hours with a few other friends to give the XJ the first run on new Clayton's suspension...Almost did not have a jeep since the rear exhast exit was a bit to close to the axle truss ,and got pushed up during up travel on some parking lot flex ,and was pointing right on the fuel tank above the skid and heated up the plastic and then the exhaust tip poked through the tank ...i found this at the gas station when i filled it up and gas started pouring out...got it home using tire plugs ...but it's fixable for the weekend...i think i'm going to just cut off the exhaust and do a belly dump since there is to much stuff in the way out back now . I'll be running down to Denver to meet the group then heading up to Spring Creek , So if you see me feel free to join ...you really can't miss my XJ , So if you see a very wide white XJ with ER on it with 40's it's me .
