Old March 9th, 2012, 05:04
Crist Clapper Crist Clapper is offline
XJ: Replacement of the Instrument Cluster
1987 XJ: Need to replace the instrument-cluster. What do I need to know? Thanks!
Old March 9th, 2012, 06:53
old_man's Avatar
old_man old_man is offline
Re: XJ: Replacement of the Instrument Cluster
It isn't hard. You pull the fascia by removing 4 screws. They all face downward. Two are above the cluster, the other two are lower with one of them by the headlight switch.
Once you finish that you can pull that fascia off. There are 6 screws that hold the actual cluster in the dash. Once those are loose, carefully work the cluster forward. There are two electrical connectors. You remove them by pushing in locking tabs on the top and bottom while rocking them to get them out. You can then reach behind and unhook the speedo cable.
Before putting the cluster back, take a pencil eraser and shine up the electrical contacts. Also check the bulbs since they commonly burn out in vehicles that old. Corroded contacts are a very common reason for gauges that don't work right.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
O-Gauge Steamer O-Gauge Steamer is offline
I suppose we would like some idea of where you are going with this. Are you wanting to plug in another stock cluster or, do you intend to replace all of the gauges with aftermarket? Both have been done and there are some good threads on what is needed.
OK, old_man... you are quicker on the draw than I am. Your post popped in just as I hit post...
Last edited by o-gauge-steamer; March 9th, 2012 at 06:55. Reason: Kudos to old_man!
Old March 9th, 2012, 07:40
Shorty Shorty is offline
I'm fairly sure you will want a cluster from '87-'90 that matches your engine size assuming it will have a tach (4cyl and 6cyl tachs will differ)
once that's accomplished, you will need sending units for the style cluster you are installing-- gauge units for gauges, idiot light sending units for lights. It's plug-n-play after that.
Old March 9th, 2012, 07:52
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Actually, it's possible to swap 4cyl and 6cyl tachs, but it requires some electronics knowledge, and use of something like a signal generator to recalibrate it.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old March 9th, 2012, 09:04
Fair question... Un-plug/plug/play. In reading responses... This seems do-a-ble. If so... What/where are good sources for a used replacement? Thanks all! Crist
PS: I'm just getting started with this stock-restoration. So I'll be asking alot of questions... So please be patient with me! The is restoration #2... Just finishing up on a 1990 Grand Wagoneer... Didn't get enough with just one!
Old March 9th, 2012, 15:25
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Make sure you have the right speedo cable and interface. The 87 differs from the later ones.
Old March 9th, 2012, 16:31
Thanks for the advice!
Old March 9th, 2012, 16:50
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Differs how?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 9th, 2012, 17:32
old_man's Avatar
I did that about 12 years ago.
Loveland, Colorado
Old March 9th, 2012, 19:50
NAXJA Member #760
Originally Posted by Ecomike View Post
Differs how?
When I tried to put an 89 cluster into my 87, the speedo cable had both a different end and a different method of attachment. It may have been due to the little maintenance clock which runs off the cable. It's been a few years, and I long ago gave away the 89 cluster. All I remember was that it was not quite plug and play, and that I decided to skip the job since the cable was pretty heavily corroded in at the transfer case end, and it seemed too much bother just to get a tach.
Old March 9th, 2012, 20:08
old_man's Avatar
When I did one of my swaps, one cluster was a push on configuration the other had a screw on retainer. I had a speedo shop local and he simply changed the end on the cable. I could have looked through the cables at the parts store and probably found one. As it turns out, speedo cables are pretty cheap.
Loveland, Colorado
Old March 10th, 2012, 02:56
all true^^
I'll update/change my response to read "you will want a cluster that matches your engine size assuming you have a tach (and don't want to create a signal modifying generator to alter a 6cyl signal to 4cyl or vice versa) ....
possible? yes
worth the effort? probably not (unless you've got a 4cyl and just have to have a tach before one turns up in the boneyard)
Old March 10th, 2012, 11:05
Ecomike's Avatar
NAXJA# 2091
I used the local shop myself and a had a custom cable made to adapt the Nissan diesel Tranny in my 85 to the 85 Cherokee dash speedometer. It ran about $85, which I thought was cheep too. It is now one of those endless roundtoit tasks on my endless list, to install the cable, LOL. I still use my butodometer to avoid speeding tickets, LOL.
I bought a digital transducer gadget for the tach on the SD-22 diesel (as there was no way I could think of to adapt it to the dash style gas Techs) to add the tach to mine.
http://www.tinytach.com/tinytach/diesel.php
No doubt there are aftermarket tachs for gassers too.
Old March 10th, 2012, 11:26
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
The tach is indeed calibrated for the number of cylinders - on a RENIX rig it is timed off the logic-level ignition pulse signal from the ECU to the ICM, so this kinda makes sense. If you put a 4 cyl cluster in a 6 cyl it'll read 50% more pulses per revolution than it expects, so you'll get tach readings that are 50% too high. If you put a 6 cyl cluster in a 4 cyl it'll read 33% fewer pulses per rev than it expects, so your tach will read 33% low (i.e. ~500rpm at idle, when it's actually running ~750.)
If you wanted to recalibrate one it wouldn't be too hard...
signal generator frequency for a 1000rpm reading, 4cyl: 4 pulses/rev * 1000rev/min / 60sec/min = 66.67Hz
signal generator frequency for a 1000rpm reading, 6cyl: 6 pulses/rev * 1000rev/min / 60sec/min = 100Hz
I *think* I got those numbers right...
As long as you have a decent digitally controlled signal generator and can adjust the knob yourself (iirc it is a small variable resistor on a PCB inside the instrument cluster behind the tach) it should not be too hard to recalibrate.
Some of the speedo cables are still in stock IIRC, but some aren't. Vehicles with cruise control have multiple sections of speedo cable because the transducer for the cruise system is installed in the middle of the cable, somewhere under the dash.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
instrument cluster won't dim xj_chef OEM Tech Discussion 3 September 25th, 2010 13:15
Instrument cluster for my '96 xj pkbinder Wanted: Private Party Only 4 April 26th, 2010 12:52
Instrument Cluster bajacalal FREE Items. No SPAM 3 March 7th, 2007 20:14
instrument cluster 89comanche Wanted: Private Party Only 4 January 3rd, 2004 22:19
instrument cluster on 98 XJ Rescue Ray OEM Tech Discussion 5 April 2nd, 2003 04:41
