jrowell
- Bakersfield
I lost a u-joint on my D30 (it didn't break, I think I lost a cap) which in turn broke the ear on my Drivers side long shaft. While swapping it on the trail, we noticed that the knuckle had slipped down about 1/4 an inch on the ball joint. After swapping in a spare axle, we put a little weight on it and smacked it a couple times and it reseated. Dove it home and it was fine. Jacked it up and tire does not wobble, so it seems lick the ball joints are tight. They only have about 2000 miles on them. Could the force between to ears grinding together cause the ball joints to sperate like this? Should they have seperated? Is it normal?
thanks for any info,
Jeremy
Jeremy
