JeepAddict85
- Nashville, TN
Bought an 8.8 off of TrailRateThis (thanks!!!)...started to clean it up:
Its already got the spring perches welded on, just need to weld on some shock tabs. 410 gears, (im still at 3.55 though), disc brakes, even abs which i will try to get working with my xj's. In the pics you can also see my HP dana 30 im working on, that will take the place of my low pinion. Im thinkin 4.56 gears, maybe auburn ected rear (goes from limited slip to full lock on flip of switch), and selectable locker upfront like an arb or something that can remain 'open' until engaged.
