BrettM
- michifornia
My 88 4.0 has about 220k miles on it and a serious blow-by problem when I head up into the Sierras with the 35s on and loaded for the trail. It runs just fine, maybe a little low on power but I don't have much to compare it too, but the blow-by is just crazy, probably 1/2 quart in a real strenous 600 mile trip. I've replaced all the appropriate lines, cleaned the valve cover and snorkel things, but none of that helped much at all.
I really want to make it through the summer wheelin season (under 2000 miles) before replacing or rebuilding the engine. I am perfectly content to build a good catch-can and be sure to replace oil as needed, but would this actually be bad for the motor in any way? Does this severe blow-by indicate that my motor is on the very verge of going kaput even though it runs fine in every other regard?
