2004 Axle&Diff off Liberty - fit XJ?
Nixt
Hi, there's an auction for a 2004 Dana 44 out of a NZ Cherokee, which is called the Liberty in the States.
Will it fit under an XJ? Especially Width? I know I'd need to cut off the coil spring mounts and add ones for the leafs - but it's CHEAP and nearly a decade newer than my D35C. Has the same ratio, too!
I have an hour before the auction ends to find out.
Width is probably close to the same, You'll have to cut the coil perches off and weld on some perches for leaf springs.
