truck7575
- georgetown
Anybody who has done this swap and used the JKS tie rods with WJ TRE's on a Dana 30. Also I have done a Tie Rod Flip using Goferit offroad inserts. I am having trouble with the passenger side sway bar interfering with the steering linkage between the pass knuckle and the pitman arm. Can anyone show me a picture and give me a list of which TRE part number you used in each location including the driver and pass TRE and driver and pass steering link. I do have the Right Hand Drive TRE installed on the passenger side tie rod connection. I am afraid that I have all the right TRE's but just them swapped around in the wrong locations although I cannot figure out a different setup that improves my situation. And of course I know I should have went with 1-ton TRE's but i didnt so can anyone help me here.
Thanks
Rick
Thanks
Rick
