'90 Bendix ABS swap - 1 thread source?
JeepFan3
North Carolina
I've just about reached my limit on my Bendix ABS system and want to do a conversion. I've searched the threads and found a bunch of info - maybe too much as I am now so overwhelmed I don't know what to do.
Is there one good thread that tells:
1. What is the best swap to do
2. Exactly what parts are needed,
3. A step-by-step guide on how to do it?
Thanks for any help or information!
Remove all associated ABS parts. Find a WJ booster and master cylinder, aluminum spacer, and a cherokee prop valve. Carefully grind the booster rod so it is flat just like your old one. That is key for proper brake light functioning. The hole needs to be drilled out too I believe. You'll have to bend and flare a few lines as well. Look at starboardM 's thread about the swap. I did it on mine a few years ago too.
i just kept all the old bendix lines and the new lines from the wj, bent what i needed to re-use, or cut and re-flared the lines for different fittings.
