Old June 13th, 2018, 12:49
burntkat burntkat is offline
NAXJA Member #1145
Re: NP231 Black Fluid.....
I would think were already talking about a 231C. It would cost a lot more to buy a adapter to go 4L60-231J.
You'd be surprised how many people do it, though, out of not knowing better.
I believe he bought this truck already built- so while Clyde is a sharp cookie, not sure about the PO.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old June 13th, 2018, 12:54
NAXJA Member #1145
Originally Posted by TRCM View Post
I'm not so sure I would run the planetary if it has had that black contaminated fluid in it.
I'd at least flush the dog pee out of it.
It may look good, but who knows when it will decide it is done.
This.
At the very least, the oil pump needs to be replaced. It may well have been the failure to begin with (I am betting that is the case).. the OP failed, the shift fork nylons melted, the fork gouged the component it contacts (drawing a blank- shift collar?) and frag went throughout the assembly.
New chain if it fails the slack test, new bearings and seals, OP, shift fork and nylons, and inspect everything within an inch of its life. If too much is questionable, consider sourcing another unit and transferring the SYE over. It will likely be a hard call- rebuild or replace the entire unit. I know you can find 231s cheap out here. Maybe time for an upgrade to the Rubi case? Of course an Atlas is always a possibility, but I think if that made much financial sense we'd probably be talking about a built TJ at the very least.
Old June 13th, 2018, 14:37
clydefrog's Avatar
clydefrog clydefrog is offline
Originally Posted by burntkat View Post
I believe he bought this truck already built.
I built everything on the truck, its been in my family since '93 (assuming your talking about mine). It became mine in 2013 when i asked my dad for it (it was sitting in his field growing weeds and full of water). Thats why i want to keep the existing t-case since i know where its been etc...
Also this t-case is really wierd. According the numbers stamped on the side it is an AMC 231.
I was considering an atlas, then my dog ate something so yeah.....
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old June 13th, 2018, 14:48
clydefrog's Avatar
prob hard to tell but the thing is completely disassembled and the parts have been cleaned. I even assembled the t case halves together with the shift fork installed to see if there is play and there was no play.
Honestly, I remember when i rebuilt it i had trouble getting the nylon bushings on the fork. Come to find out this time around that the '87-'88 have a different shift fork. I vaguely remember trying to force the nylon bushings on and they weren't really on right but i ran it anyways. Not doing that again!
Old June 13th, 2018, 17:07
TRCM's Avatar
TRCM TRCM is offline
From having built rebuilt t-cases & transmissions, I know what a planetary looks like.
My concern would be the bearings and surfaces on the shaft the gears ride on....you can't see them unless you 'break' it apart. I'd also try to see if you can find a 6 pinion planetary to use....would make it handle the V8 much better.
When I rebuilt my last 727, we used planetaries from the cummins auto transmissions to strengthen mine. We were able to double the pinions on all planetaries.
Old June 14th, 2018, 09:55
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I would at the very least disassemble, clean very carefully, and inspect every precision ground and hardened surface for damage. Any sign of damage? Scrap it.
Make very certain that you clean the oil passages on stuff, they're probably packed with metal filings and globs of plastic.
Bet your fork issue was the root of it... but I'd be real tempted to start with a clean case that you know isn't a pile because it's got clean fluid, install your SYE and input gear and move on with your life.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old June 15th, 2018, 05:57
NAXJA Member #1145
Yes, they should be neither a loose nor difficult fit. I think you've found your failure mode.
Old June 15th, 2018, 05:58
NAXJA Member #1145
A similar trick is done to 700R4 trannies to strengthen them. Use the 6 pinion planetaries from the 4L65E
Old June 15th, 2018, 10:07
clydefrog's Avatar
Found a np231 on Craigslist for $25. Gonna pick it up tomorrow and salvage stuff out of it, or rebuild it completely with my parts (SYE and upgraded 27 spline input shaft). I may try to make a 6 gear planetary with the planetariums that i will have. And I have a new pump, pickup screen, bearing and seal kit on its way as well as a new shift fork.
Also, may be a bit overkill but i will be drilling and tapping the case for a 220 degree warning light sensor and mounting a warning light next to my trans temp gauge. What are your thoughts on 220? I can do 210 or 230 as well, My guess is anything north of 200 is a bit much.
Old June 15th, 2018, 10:30
TRCM's Avatar
ha ha ha...planetarium is a building....planetary is a gear.....but we get yer drift
just made me chuckle.................
Old June 15th, 2018, 10:54
clydefrog's Avatar
haha, it must have spell checked it. I meant to say planataries.
Old June 15th, 2018, 11:00
kastein's Avatar
I'd actually consider putting a gauge in instead of a warning lamp. That way you can get an idea for what temps it rides at under what conditions and tell if something seems out of whack. Maybe a second trans temp sensor with a switch to select which you're looking at?
I know my bone stock NP231 behind a stock 4.0/AX15 will get hot enough to give mild second degree burns to the back of my hand while prying the shift lever away from it (I didn't have a linkage hooked up...) but I'm not sure what temp to expect normally.
NP231 slip yoke lose fluid? Jeep450r OEM Tech Discussion 2 April 1st, 2012 20:10
Quick NP231 Fluid Question 4WDlifeform OEM Tech Discussion 25 March 11th, 2010 20:27
tcase fluid? np231, atf or gl4 or gl5 german996 OEM Tech Discussion 2 April 3rd, 2009 09:33
NP231 fluid (atf or gl5) question , please help german996 OEM Tech Discussion 16 September 13th, 2008 04:50
