Old June 11th, 2018, 07:08
3blackbirds 3blackbirds is offline
0630 Exhaust Manifold Constantly Cracking
Hello all,
I'm trying to figure out this issue for my 1999 Cherokee with 0630 head.
Within the past year:
Stinky Fab Racing Motor mounts.
(I've had M.O.R.E, but they're a bit too stiff for me)
OEM Trans mount
Mandrel bent down pipe with 6" flex joint.
I keep breaking manifolds at the welds every 2 years. I've gone from cheap to APN and Dorman. I'm tired of doing this job. I've just replaced my 4th.
My next move is to put the two piece cast exhaust manifold from the 0331 head, plug the 02 sensors and have a new down pipe made up with a new bung for one 02 sensor. I know I'll need an adapter plate because the 0331 manifold won't cover the 0631 exhaust ports. Yes, a more restrictive manifold but I'm tired of the cracking. I have a 4" lift, so piping will clear the driveshaft.
Is there anything I'm missing or can consider before I put the two piece on? I don't want to spend hundreds on this for an aftermarket two piece right now. I'd like to get this set up and stable before I purchase a nice Borla or Banks etc. down the road.
Thanks in advance
Old June 11th, 2018, 07:51
RCP Phx RCP Phx is online now
Re: 0630 Exhaust Manifold Constantly Cracking
Why not just purchase a good header? It will compliment whatever you do down-stream later! I have the Banks Revolver and it been great.
Old June 11th, 2018, 07:57
I've read that they crack too. I don't want to spend ~$400+ on a good one just for it to break. There's gotta be something that I'm missing to prevent cracking.
Old June 12th, 2018, 20:57
JeepNoob JeepNoob is offline
Borla makes (or at least used to) headers and even a down-pipe for 4.0 XJ's. It's expensive, but they also warranty their exhaust stuff for "A Million Miles." Even if your have to change it out every 2 years, the only thing it should cost you is time.
Old June 12th, 2018, 21:07
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I have been running my Borla for a bit over three years now. No issues.
Old June 13th, 2018, 04:23
old_man's Avatar
old_man old_man is offline
The only hints I can give is to make sure and use Bellville washers and ideally use a flex pipe section after the header. Make sure the exhaust pipe is supported, not just by the header at the front. Put a hanger where it goes from crossing over and starts rearward.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old June 13th, 2018, 13:16
sinat01's Avatar
sinat01 sinat01 is offline
honestly I use a $70 header off ebay that has the flex pipes in it. I had a ATP but it cracked really badly
Old June 15th, 2018, 06:31
I'm looking into mounting the exhaust at the cross member differently. I want to permanently fix the issue that is causing these manifolds to crack.
0630 head on an 01 - exhaust??? watson OEM Tech Discussion 12 September 20th, 2012 19:48
Intake manifold and exhaust manifold gasket replacement.... 1990Pioneer OEM Tech Discussion 4 August 9th, 2011 04:24
1999 0630 head/exhaust questions sharq OEM Tech Discussion 3 May 5th, 2009 13:13
Jeep 2.5L exhaust manifold keeps cracking Schris1 OEM Tech Discussion 17 December 17th, 2006 19:02
97+ intake manifold and performance exhaust manifold BigG Wanted: Private Party Only 5 September 22nd, 2006 17:45
