Sea Foam Treatment
Ertsride1
Springfield IL
Have you noticed that your engine is lacking the power it used to have...maybe it's a lil tired.
I have used Sea Foam in all my vehicles and have had excellent results.
1. Purchase 2 cans of Sea Foam
2. On your way home fill up fuel tank
3. Find measuring cup(I used my wife's Pyrex)
4. Pour 1 whole can into fuel tank
5. Pour 1/2 can into measuring cup(8 oz's) and set aside
6. Start your vehicle and let it get to Operating Temp
7. Locate Main vacuum line going from brake booster to intake manifold
8. Remove vacuum line brake booster elbow
9. Pour measured amount of fluid into vacuum line.
a. As quickly as possible without letting the engine die
10. IMMEDIATELY hook-up vacuum line to elbow and kill the engine
11. Let vehicle sit for 10-20 mins
12. While waiting...pour other 8oz's into the Oil Fill hole in valve cover.
a. only complete step 12 if vehicle is within 25-30 miles of oil change
13. Start engine and sweep rpm from idle to 1500 rpm until it is done smoking.
This system will clean up all major systems and restore performance to your engine.
Thanks for Reading,
Garrett
