Tubing size for LCA's
xj92
I'm planning on buying some tubing tomorrow to make some new LCA's. What's a good size to use on the ends so I can use common, cheap poly bushings (outside diameter and thickness)? And I'll probably weld it offset like the RE arms to get a little extra droop in the suspension, so I guess I'll have to use a different diameter in the middle than on the ends, but that size shouldn't be that important. TIA.
Yep, been reading that and debating on that or trying to make them even cheaper by just cutting and welding tubing, we'll see.
