Old March 30th, 2021, 06:57
Evan03 Evan03 is offline
Modded steering pump.
So my pump is quitting offcourse.
This is from parts jeep. Drilled to 5/32
Will remove washer and stretch spring.
Anyone done this.
Good info here and on pirate on this mod.
Old March 31st, 2021, 10:51
The pump still bolted to my xj was set up for more pressure.
I made a socket.
Its spring was slightly longer it also didn't have the small washer.
I drilled passage to 5/32 and cleaned the screen.
It might be temporary but it now steers great again
Old April 7th, 2021, 18:40
Did some more tinkering, neat ain't it.
Old April 8th, 2021, 09:27
XJlimitedx99 XJlimitedx99 is offline
Re: Modded steering pump.
Think this is the first I've seen of this mod. Got any links to share for more reading?
'99 XJ - 4.0, AW4, NP231, HP-D30, C8.25, 6" Lift TnT Long Arms on 35s
Build Thread: Project Go Anywhere, Do Anything, Anytime.
Old April 9th, 2021, 01:32
No. Theres old threads here and lots on pirate. Took Google digging to dredge them up.
Old April 15th, 2021, 05:47
denverd1 denverd1 is offline
Curious if an underdrive pulley would help
Old April 15th, 2021, 06:39
Suposebly it does help theres mention of smaller pulleys on pirate but I didnt find any though I didnt put much time into it.
I did take the electric fan off the parts jeep and wired it into my jeeps factory wires. Supringly the dam thing turned itself on. It appears it may actually help cool the power steering pump.
Do all xjs have electric fans?
Old April 15th, 2021, 06:49
Anak's Avatar
Anak Anak is offline
Stranger
I doubt the early V-6 years had electric.
I don't know about the Renix years, but my guess is yes.
I am fairly certain all the H.O. years do.
Old April 15th, 2021, 06:59
RCP Phx RCP Phx is online now
I run the PSC pulley and it has worked out great.
https://naxja.org/forum/showthread.php?t=1148990
Old April 15th, 2021, 08:04
Was kinda amazed it worked had to cut the harness out of the parts jeep and wired in to to unused wires on my jeep popped tge hood after a long climb and fan was running.
Nice I may try the pulley. Supringly my steering is revived after cleaning and mods
WJ power steering pump upgrade vs PSC pump upgrade hot_rod_hooligans Modified Tech Discussion 52 April 24th, 2019 12:27
steering box or power steering pump? Demonoid369 OEM Tech Discussion 45 January 22nd, 2013 15:46
Remote steering pump fluid reservoir for stock pump mountainjazz Modified Tech Discussion 17 March 27th, 2012 12:43
89 XJ Steering Gear Box, PS Pump, and Steering Shaft For Sale waxer SoCal For Sale 4 June 22nd, 2008 12:34
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 12:38
