Jeep keeps dying when I put it in gear, starts in neutral and park, then dies...
Big Red
Roscoe, IL 61073
I have a 91' 4.0L HO, AW4 auto 231 stock XJ with 180K miles. I can get it started and just replaced the battery in it because the old battery was bad. I just passed smog and used my portable jump start to jump my old battery and I cannot. So I go to the store and get a new battery, put it in and get under 1/2 mile down the road and it dies. I start it up, rev it, and when I put it into drive it just sputters and dies even if I punch the gas..over and over again for an hour. I just have to get my Jeep less than a mile to get it home and I have it sitting in a parking lot at the moment. I'm waiting a few hours for the streets to clear of traffic in Sacramento before I'm going to attempt to limp it home again. 1 thing I noticed is I have a ground wire mounted to the passenger fender that is stock, but it broke from the neg battery terminal, I electric tied it to it is making contact, but a few times the Jeep wouldn't turn over and then when I touched the neg ground fender wire to the battery post, it will start. But I cannot even get a few feet of starting the Jeep and then putting it into gear where it just dies
To make a long story short....I get my jeep started, I put in in gear and it dies. I just need to get it home and don't want to pay $60 or so for under a mile to have it towed. Any ideas???
thanks,
Troy
I waited till 4 a.m. incase I had to tow the XJ with my 98' ZJ. It started right up and I drove it home no problem.
I had this same thing happen to me when driving my brother-in-law's 91' XJ. It was fine on 4 miles of surface streets and on 6 miles of hwy, but as soon as I got off the highway on the exit ramp and had to stop at a the light it died and everytime I put in in gear it died. I finally got my rpms up in neutral and through it into drive and get the revs up to make it the mile to my bro's house. Other times it starts and runs no problems. Does anyone know what it could be that it cranks over and is fine in park and neutral and dies even with the gas pedal planted when putting it in a drive gear?
langer1 said:
You need to clean/replace the battery connectors, look closely at the smaller wire comming off the + terminal.
My battery cables are pretty corroded. I just put a new battery in and tried to get off as much corrosion as I could without tools. I started the XJ up and it drove fine after letting it sit for 6 hrs. Really weird. Is this a 91' 4.0L HO thing because this is the only XJ year I have seen this happen? I have had 3 89's, 3 91's, 1 95 and 1 96' XJ.
It’s a common problem, you know where to start. Whats happening is your starting off the battery but running on the alternator because of a bad a connection.
As soon as you try to put it in gear your RPM is too low to stay running
Thanks langer1, I'll get some baking soda and a good brush and clean up those battery connections. What about the wire that mounts to the passenger side fender? Is that a main ground of some sort? The wire originally was connected to the negative battery connector, but it broke off and I tried as best I could with no tools to strip the wire protector off to get a decent connection. Many times I got the Jeep started, but then it would die in idle, I only had good luck starting it again once I got the fender wire connected to the neg. I let it sit for 6 hrs because I was waiting for the traffic to be way down incase I had to tow it with my ZJ, but it fired right up and I drove it the mile back home.
You the man langer1, thanks alot. :wave:
Troy
