Old November 5th, 2019, 17:42
Black1990jeep Black1990jeep is offline
Best air filter for a stock 1990 air box.
I have had some Fram airfilters collapse into the air box, their frame is not very rigid, and thus it can come out of the channel easy. Is there a filter with a more ridged frame, better fit?
What is a high quality filter to fit the stock 1990 air box?
Thanks!
Old November 5th, 2019, 19:21
RCP Phx RCP Phx is offline
Re: Best air filter for a stock 1990 air box.
As told before, that's a malfunction of some type, but anyway I use the Afe washable.
https://afepower.com/afe-power-31-10...y-s-air-filter
Old November 5th, 2019, 21:19
devildog0's Avatar
devildog0 devildog0 is offline
You can still get them from the dealer. Thats where i got my last one just cause i happened to be in there for another part. IIRC its stamped as a Mahle filter but id have to double check tomorrow.
Rockauto carries a wide selection of good name brands. Id be wary of using washable oiled filters.
https://www.nicoclub.com/archives/kn-vs-oem-filter.html
Sent from my SM-G892A using Tapatalk
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old November 6th, 2019, 05:54
Rockwood Rockwood is offline
High quality paper is the way to go, and replace often if you're off road a lot as dust migrates through them eventually. Rockauto.com currently has non-labeled/packaged (think sales to Jiffy Lube type places) WIX filters for $2.54 each. Otherwise, Mopar or ACDelco seems fine.
I've used oil filters for desert buggy go-fast stuff. I've never had good luck with them and always had dust in the intake until I switched to Donaldson type paper filters.
Old November 6th, 2019, 07:56
Is this the Donaldson filter you recommend?
link...
https://shop.donaldson.com/store/en-...P534105/19636#
Old November 6th, 2019, 08:06
From your link, AC Delco seems to be the best.
But my issues is the filter failing to stay seated in the air box channel. When I bought the jeep the K and N was fallen out of the channel, I replaced with fram paper filter and now twice upon inspection it has fallen out of the channel of the airbox. my air box is stock, and does not appear to have any warps or deformation in it or its top. It is nice and squared,no twist in the plastic.
I think if the wire mesh on the filter was stiffer, or the frame beefier that would solve it, The filter did not get wet either, the filter element seems undamaged each time, I think it is a poor design issue, it needs a more rigid frame, that is what I am looking for at this point, a filter that is more rigid.
anyone else have this problem?
Old November 6th, 2019, 08:55
devildog0's Avatar
Heres my filter. Oem MOPAR. One thing i noticed on the metal grille ontop is two raised rectangular sections. I assume these add somewhat to the strength to the mesh grille. And its not marked MAHLE its just got the Chrysler marks. Ive never noticed these raised sections on other brands of filter but ive never payed that close of attention to it either.
Ive never had what youre describing happen. It may be time to get a replacment airbox. Maybe yours is warped and misshappen and no longer able to hold the filter properly.
Old November 6th, 2019, 12:03
link...
NICE! I didn't even know they made one, but makes sense. Yes, Donaldson is a good company.
As far as I know, almost every filter I've put in the Jeep was pretty floppy. The mesh is to keep the paper from getting sucked into the engine, not to keep the filter rigid. I think you have a problem with your airbox.
Old November 6th, 2019, 18:29
devildog0's Avatar
https://teamcherokee.com/lower-air-c...kee-1991-2001/
Old November 6th, 2019, 22:29
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I have a case of motorcraft filters from when I worked at a Ford dealer, that will last me a while. Otherwise, I was using Napa and Carquest filters.
Will probably run Wix after.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
FS: 99+ Stock Air box / filter / tube djblade311 SoCal For Sale 6 August 15th, 2012 07:46
1990 fuel filter & shift lock question??? cherokee4fun OEM Tech Discussion 5 February 8th, 2007 21:41
K&N Air Filter for the stock air box 4ESTJP For Sale: Private Party Only. XJ ITEMS ONLY 1 February 15th, 2005 10:16
K&N Filter Stock Air box nateo101 For Sale: Private Party Only. XJ ITEMS ONLY 3 January 31st, 2005 08:03
