Dannymmz
- San Antonio TX USA
Need help with the alarm system on 01 XJ. I would like to install the dealer system ($160), it's plug and play. It's better than a self install system ($90~140)for which I would have to run new wires and rewire the door locks along with other things to make it work.
But first I would like to know how and what will set off the XJ alarm?
My old rodeo alarm would be trigger by several factors:
(1) Would set off if it is unlocked from the outside or inside.
(2) Would set off if a door or the hood is opened.
(3) Would beep & not set if you try to set the alarm with a door/hood
open.
(4) Would auto reset it's self if a door is not opened after unsetting / unlocking doors.
(5) Could also be set/unset & lock/unlock all doors using the key the driver's side door key hole.
(6) Would unset and unlock only the drivers door on the forst press of the keyless unlock botton.
How many of these preset factors are true with the 2001 XJ?
I know with my 01 XJ keyless entry that
(1) One press of the keyless and ALL the doors unlock.
(2) Doors will lock even if a door is open and will not beep about it.
(3) The driver's door key hole is not wired, so no controling the system by the door.
(4) It Will not reset itself.
If I find a 01 XJ at the junk yard do some of you know where the alarm control box is located?
open.
