I have truly given this issue my all, so I yet again turn to the knowledgeable enthusiasts here at .
About 3 years ago, my automatic 98 Cherokee Classic would not start one day. Problem wound up being the neutral safety switch. Unfortunately, the switch wound up freeing itself from the transmission in a destructive way so rebuilding was not an option.
Since then, I have had 5 of these switches on my vehicle.
1. Ebay special - worked for a week, then vehicle no longer started.
2. Warrantied Ebay special - actually worked for two years or so.
3. Came from Amazon - worked for 6 months, no longer shifts into 4th.
4. A different one from Amazon - defective out the box, returned.
5. Came from boneyard - Mopar unit, rebuilt by me. No 4th gear.
Here is what I have tried (besides replacing or rebuilding the NSS):
- fuse #10 has been replaced with no difference
- all grounds have been cleaned multiple times
- I have cleaned the NSS connector itself
- I have reset the ECU several times
- switch has been adjusted by loosening small bolt, marking threshold for reverse lights, and going smack dab in the middle of that
Here is what I know:
- if it's over 60-70 degrees out, there is a good chance it will shift into 4th gear if I clear the codes. It will stay in 4th with no CEL. I don't know if this is related to the issue or not.
- it starts every time in park, needs jiggling in neutral
- if put the vehicle in the run position, clear the codes, start it, and hit 45 mph, it will shift into 4th. However, it will kick itself out of overdrive and turn the CEL back on 10-15 seconds afterward.
I know the code P0700 is just a generic code that says something is wrong in the transmission control system. The P0705 states "Transmission Range Sensor Circuit Malfunction (PRNDL Input)" on my cheapie bluetooth OBD II reader. I'm starting to wonder if some wire somewhere is shorting out and it's just hidden by split loom. Before I start tearing into everything, I was hoping for some input. My last resort is currently the $350 Mopar NSS lurking in my browser, and I'm really hoping it doesn't come to that.
