    More Information - Join/Renew
Scotts ZJ.. AKA Reggie the redjeep
your going to love the ori struts.
i have a set of 14" ori's in my red heep, they work great, no need for a swaybar.
why did you decide to put coils in back instead of ori's?
The rear is kind of being cheaped out on for now, coil/shock/limit straps etc and a welded diff
I decided to do the front right and I'll re-do the rear sometime down the road with a ZIP locker and ORI's
good idea. they are pricey little bastards, but your going to love the simplicity & performance they offer.
Simplicity is what really intrigued me.. Im really hoping to never need a swaybar
i've had the swaybars disconnected for a couple years on both my street xj's & my trail rig never had one.
I agree with Dustin.
So why’d you stay radius arm? Simplicity?
I actually ditched the radius arms for a 3link setup
You know, for weight reduction.
Will 2019 be the year?
I would hope so! You have been working on that since I retired.
Hope to see you on the trail again some day though. Although I do have a new rig in the works. More of a exploration vehicle. Crew cab, short bed, 33’s and lockers.
Last winter I took the jeep out on a snow run in the Guilford pinchot that went very bad My Clayton's 3pc crossmember sheared at a flange weld on the passenger side and then the whole driver side of the crossmember proceeded to rip off the frame stiffner and unibody. Essentially making 2 out of 3 control arms free float. So the front end was being held in place via 1 lower arm, panhard and driveline.
Long story short I had to ditch the jeep and retreat to town and devise a recovery plan.. That was such an awful feeling.
After a day of planning and recruiting a small army on a sunday night, luckily we found the jeep under an additional 10" of snow. Which I truly believe is the only reason my rig wasnt pillaged and torched from scavengers. So lucky!!
Thanks to Torx, Redjeep2.0, BigPimpinBen, and a handful of other people that stayed out till 2am on a work night. We setup a repair station to band-aid the jeep and recover it off the side of the mountain.
Spring 2020 i moved to Texas and left my toys behind, including the Jeep in its broken state. I got ahold of Clayton off-road and they stepped up huge. We agreed that a skid plate would of probably helped tremendously when everything started pulling itself apart. They sent me a brand new version of their 3pc crossmember as well as a belly skid.. So I flew to Oregon and a buddy helped me with R&R
Game plan is rear ORI's and a rear bumper.. And maybe even step back up to 42s again?
