sprinkler1228
- Raleigh,NC
I installed a set of daystar motor mounts on my 91. I also was having someone do my rear main seal. I finished my mounts and let my friend take over on the seal. I never started it or test drove it after the mount install. I test drove it after the seal was done and it started up fine. Good oil pressure. No leaks. I drove it around the block.By the time I got back it was leaking oil and ideling very rough. I checked under the truck and saw the oil pan was leaking. I called my buddy back and he said he thought it might leak! He had lost a few bolts for the pan and didn't wanna tell me. Is it possible the rough idle is from a vacuum leak since the oil pan is leaking or would it have something to do with the mounts? I normally would have down all the work but since I rolled my 99 a few months ago on the highway my back couldn't take it. I would appreciate any help.
