Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter
Colorado Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old January 18th, 2012, 18:36
NewBreedCustom's Avatar
NewBreedCustom NewBreedCustom is offline
Water pump question
The pipe that screws into the top of the water pump and hooks to a coolant line is rusted onto my old pump and I can't get it off. Is this something I can find at a local parts store or is this a dealer only item? And what is the correct part name? I am having no luck finding it.
Old January 18th, 2012, 21:21
in4aride in4aride is offline
Re: Water pump question
pic?
Old January 18th, 2012, 21:26
SleeperXJ's Avatar
SleeperXJ SleeperXJ is offline
I guessing it's the heater line you talking about.
Not sure what the official name is but it is available at the dealer.
Old January 18th, 2012, 23:06
Ok, I think I have established that it is called the water pump inlet tube. I have found it for everything else but a renix version.......
Old January 19th, 2012, 04:46
Hypoid's Avatar
Hypoid Hypoid is offline
The RENIX engines I've worked on had a straight pipe nipple and a molded hose. I've switched every one to the HO pipe with a straight hose. The threads are the same.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old January 19th, 2012, 05:56
Joe94xj Joe94xj is offline
Homedepot have anything maybe? Try the help section at advanced auto?
Old January 19th, 2012, 08:24
O-Gauge Steamer O-Gauge Steamer is offline
From my parts list.
Jeep Part Number: 5300 7978
Nomenclature: TUBE, Water Pump Heater Return
DORMAN Part # 56398 {#53007978} From RockAuto.com.com $7.12 from them...
Old January 19th, 2012, 10:23
Thanks for the help fellas
Rate This Thread:
Water Pump Question yardape OEM Tech Discussion 5 September 2nd, 2010 16:58
Water pump question? THEPATRIOT OEM Tech Discussion 21 October 12th, 2009 11:14
water pump question JeepinMass OEM Tech Discussion 11 February 20th, 2008 14:21
Water pump question... adam.gutt OEM Tech Discussion 6 March 23rd, 2006 16:57
90 4.0 vs 97 4.0 water pump question tmacie OEM Tech Discussion 9 October 16th, 2005 19:38
