Clicking Noise While In 4 Wheel Drive HELP!!!
xjhandy
Vancouver, WA
long story short- I have always had problems with my 4 wheel drive engaging and the vacumn for it has always been messed up. Therefore, I decided to go to a manual pull lever for the four wheel drive. Im basically duplicating what they sell for upwards of 180 dollars at other places. Anyways I finally got it all dialed in and the 4 wheel drive goes in and out. Now after all that work i have a clicking coming from underneath. I need some help please!!
-could it be fluid
-could it be the u-joints in the driveline
-could it be the driveline itself
-please help me !! thank you in advance for all your advice
xjhandy said:
-could it be fluid YES
-could it be the u-joints in the driveline YES
-could it be the driveline itself YES
the only way to find out is to get underneat and look. no offense, but if you were able to convert/install a cable actuator for your front axle, then you should be able to check out your fluid, u-joints and anything else.
i also recommend that you actually pull the front driveshaft to check the u-joints. i've seen some bad front driveshaft u-joint get overlooked because there was enough load on them in the vehicle that you couldn't tell.
If it happens really badly in 4 or during turns it is probably axleshaft u-joints.
Did you change the driveline angles at all when you put on the posi-lock? I can't see how/why you would, but if it was silent before and now all of a sudden you've got noise, I highly doubt it was something like spontaneous angle change or Front DS U-joint failure...
shaft U joints are cheap and super easy, why not do them anyways?
Fluid...well I mean, c'mon...
Was the silence before due to the fact that you simply weren't using 4? If that's the case then I'd look at the DS u-joints too...
How do the gears look in your front diff? If you've had a history of problematic engagement with 4, are you sure those gears are all good?
The last one is a stretch, but it is also the only thing that's been mentioned the folks around here might possibly not consider as routine maintenance.
