Old April 6th, 2021, 22:37
ljobbins ljobbins is offline
Transmission help after 2wd to 4wd swap
One thing improved was a smoother shift between gears after tv cable adjusted.
Old April 7th, 2021, 22:16
lawsoncl lawsoncl is offline
Re: Transmission help after 2wd to 4wd swap
Where to measure the solenoids. If S2 is bad, you won't get 2nd or 3rd gear. The rear speed sensor is the tan/blk wire. It should flip between 0 and 12 volts as the output spins (on a 95, it's a magnetic switch and 98+ it's a sensor that generates voltage spikes). The meter set for a/c should see something if you put the trans in gear and xfer case in neutral so the output shaft spins.
Old April 8th, 2021, 18:37
E measured overload(no connection)
F measured 12.5 ohms
G measured 12.4 ohms
Old April 8th, 2021, 18:39
Something that kinda of dawned on me and Iíll check it out later tonight. Maybe the transfer sensor is a different model than the original model for my year. Transfer case came separately from the transmission and I never thought to look at the year.
Old April 8th, 2021, 21:00
The speedo sensor in the xfer case won't affect shifting. The trans computer is only looking at the output sensor at the back of the transmission and the throttle position sensor.
If I'm reading the diagram and your reading right, you have a bad torque converter lockup solenoid? I would have suspected the #2 solenoid for not upshifting into 2nd.
Old April 8th, 2021, 22:19
Well I didnít get a chance to do the voltage test that was suggested for the output sensor so I will do that when I get a chance. I have an extra tps so I can swap that also just for the heck of it. I figure if all else fails I can swap all the solenoids and wires from the original 2wd over to this transmission and see what happens. That is just a lot of time I donít have right now.
Transmission swap Pgw1995 OEM Tech Discussion 9 June 7th, 2019 06:05
Transmission swap Ferrari458 Modified Tech Discussion 6 August 8th, 2017 09:44
Transmission swap okBrian OEM Tech Discussion 16 March 16th, 2011 17:51
Transmission swap Boomer89 OEM Tech Discussion 1 March 8th, 2009 12:14
Transmission Swap THE NEWF Modified Tech Discussion 4 September 6th, 2004 14:15
