Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old April 2nd, 2020, 15:26
neogipson neogipson is offline
Custom transfer case linkage?
Hello everybody,
I have a 2002 Jeep Grand Cherokee 4x4 4.7L engine with the 242 transfer case and have had nothing but trouble trying to fix the transfer case linkage. I have tried the bushing 53004810 three times and never gotten the stupid thing on. So I drilled a 1/8" hole in the pin and put a cotter pin in but still nothing? Does anyone know of someone that makes a replacement for the OEM transfer case linkage?
Old June 16th, 2020, 07:31
75SV1 75SV1 is offline
Re: Custom transfer case linkage?
Boostwerks and Azzy Designs makes upgraded links. I think a few others.
Old June 16th, 2020, 10:25
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
They do but don't work on the WJ.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
smokeyyank's Avatar
Jeepoholic
Originally Posted by neogipson View Post
Hello everybody,
Ask over on jeepforum or mallcrawlin. Probably get some better insight.
04 WJ, 4.7HO
Old August 18th, 2020, 11:57
soileauj soileauj is offline
not sure if you're still looking for the linkage but you might try Mountain Vista Fabrication. They do have some ZJ parts and all are good quality.
Thanks
Transfer Case Linkage Tim00XJ Modified Tech Discussion 6 January 10th, 2009 17:56
transfer case linkage help CLOISER OEM Tech Discussion 9 December 16th, 2007 23:25
transfer case 4by linkage help? Mopar It OEM Tech Discussion 3 October 10th, 2007 20:50
Transfer Case Linkage Tub shaddady34 OEM Tech Discussion 5 January 14th, 2007 22:53
custom fabricated transfer case linkage ideas,../ bxj Modified Tech Discussion 3 August 11th, 2004 12:39
